explanation clutch disc replacement, with photos
GY200 disarmament past weeks to change my clutch discs, and since it was take some pictures and made a tutorial of disarmament.
Here I give you the link to see it, is in Spanish, but a picture is worth a thousand words. I hope you find it useful. Greetings Beto de trenque. Argentina. http://www.megaupload.com/?d=9BXGI9L0 |
aweseome. thanks. pics are very informative and a bit of google translate combined with rusty memories from spanish class results in an excellent tutorial. Like you said, "Arreglar la moto uno mismo y que luego funcione."
#3 | |
I tell you that a week after I changed the clutch plates fell off the wheel bolt breakage caused total magnetic to etator or coil. If you want a little luck I can send you by FedEx. Greetings. Beto |
Hello Beto,
Thank you for the excellent tutorial pictures. I do not speak Spanish, so I have two questions: 1. Did you find dirt in the oil pump? 2. Did you use the same tool for the oil pump and the clutch? Thanks!
#5 | |
Hello. 1 - I do not remember having found dirt in the oil pump. The special key is to get just the oil pump. 2 - The clutch basket has only one ring seeguer, in the picture is the tip of the shaft is fluted, but is only one axis, not nut. I hope that skynet is translated well and give you other instructions. jajajaja. Greetings Beto |
Beto,
I removed the oil pump cover on my son's XR200, and it was full of aluminum. The cam chain ground the aluminum case, and it was a mess. :? I'm glad that your's was clean.
