Old 08-20-2010, 02:04 PM   #1
Help needed with LED taillight on Q
My LED tailight is dying, I assume from vibration and bouncing on the trails.
It started with about 15 bulbs, now only 3 work on the taillight, but all but one work with the brakelight.
Repalcement from Q is $80! 8O
Any ideas? Can individual LEDs be replaced? I'd like to gut it and install an 1157 or two.
Old 08-20-2010, 02:05 PM   #2
katoranger's Avatar
You can buy individual LEDs, but you would need to solder them in.
Old 08-20-2010, 02:19 PM   #3
Radio Shack?
Old 08-20-2010, 02:40 PM   #4
mizke   mizke is offline
radio shack has a larger assortment of led's ranging from very small to very large led's.. another option could to go to a auto parts store and buy a pair of led tail light bulbs and retro fit them into the tail light housing and also find a plug that matches them while you are there.. if you happen to have some old worn out trailor lights you could rob the bulb socket from them.. just need a step drill and some gasket maker...
back when i had my autocross ready integra i retro fitted some acura tsx hid headlights into the stock head light housings.
Old 08-20-2010, 05:19 PM   #5
cheesy   cheesy is offline
cheesy's Avatar
http://www.superbrightleds.com All you really need.
But if that ain't enough and you feel like fettling your own LEDs, www.dealextreme.com
BTW, don't waste your $ on the Radio Shack LEDs. You can get better quality and lower prices elsewhere.
Cheesy
07 Ural Gear Up
79 Honda CX500
77 VeloSolex 4600 V3
73 VeloSolex 3800
Old 08-20-2010, 05:21 PM   #6
waynev   waynev is offline
www.digikey.com also has LED's.
Old 08-21-2010, 01:37 AM   #7
You might also consider installing a DRC Edge 2 tail light, Doc. This tail light is reasonably priced, and very robust. I have been running my Edge 2 tail light for about 25,000 miles, and it is still in very good shape.
http://chinariders.net/modules.php?n...ewtopic&t=6877
Forum member Homacide also installed an Edge 2 tail light on his Hondoid.
http://chinariders.net/modules.php?n...ghlight=#96135
Old 08-21-2010, 04:43 PM   #8
I wound up repalceing the LED bulb panel with an 1157 and an auto parts store socket for $3.
I don't think it's as good or as bright as the LEDs but I don't want to spend a lot of money on a bulb that will likely get ruined again fast.
I wrote Q Link to see if they can send me the LED bulb panel without the entire $80 light assembly.
An edge won't work for me because the stock lens is shaped to fit into the rear fender assembly and I think adding something would look bad in this case.
I'm good to go with the 1157, but I wish the running light was brighter. Since this bike sees hardly and road, and not at night, it's not too big a deal but I'm irritated.
Old 08-22-2010, 11:35 PM   #9
So Spud, when you installed the Edge you deleted the entire bottom of the rear fender? What about dirt and mud?
Old 08-22-2010, 11:42 PM   #10
It's kind of weird that it burned out that fast, usually LED's take vibes a lot better than incandescent bulbs do. That's one area where the Q's and Konkers differ a bit, the Konker uses the plain jane incandescent's instead of the LED's. FWIW I would have fixed it the same way. Hopefully Q will send you a new LED taillight assembly, you have two year warranty's on them in the States?
Old 08-23-2010, 12:03 AM   #11
I doubt the warantee will cover light bulbs. They will probably exclude that.
I've been thinking of Spud's Edge idea. I will ahve to get him to send me measurements.
Old 08-23-2010, 12:05 AM   #12
The rear end of my bike stays pretty clean, Doc. Occasionally I do get some mud on the license plate. At other times I will get a little mud on the mounting plate for my J.C. Whitney travel trunk. Removing the rear "mud flap" has eliminated a lot of weight, and vibration, from the rear end of my Zong. It is also easier to clean my bike, now that the rear mud flap is gone.
Old 08-23-2010, 12:14 AM   #13
...I've been thinking of Spud's Edge idea. I will ahve to get him to send me measurements.
Check out the two threads I referred in my earlier post, Doc. The first thread also contains links to two vendors for the DRC Edge 2 tail light.
If you post some photos of your XP200's rear end, we should be able to determine if the Edge 2 tail light will fit your QLink bike.
Old 08-23-2010, 12:17 AM   #14
I'm leaning towards the dge then Spud, unless Q can do right by me. When you get a chance please let me know its dimentions.
I may also just go with my 1157 conversion until it fails too. I just wish it was brighter. I'm PARANOID abotu good taillights for obvious reasons. I know I don't ride it on the street much or at night much, and I do have the Dork Vest but I'm paranoid. Is the Edge bright? How's it holding up? How much and where did you get it from? Easy install?
Old 08-23-2010, 12:22 AM   #15
Wheeling Cycle Supply sells an LED tail light inner kit that might work for your bike.
http://www.wheelingcyclesupply.com/s...gory&cat_id=72
http://www.wheelingcyclesupply.com/i...AAAN-75665.jpg
DRC also sells an Edge tail light designed for the KLX 250, which might fit your QLink XP200.
http://www.wheelingcyclesupply.com/s...d=72&offset=10
http://www.wheelingcyclesupply.com/i...AAAb-94216.jpg
