Lifan 163 into Honda 3-wheeler - no spark...
As everyone probably knows by now... the Lifan 200cc FML163 engine bolts right into a Honda 3-wheeler, a 1985 200M in this case. Just clearance the frame under the engine to allow for the oil drain.
I am having trouble with the wiring. No spark. None. First pic the engine connector to the wiring harness. I moved the Black/Red wire on the harness side to match up with the engine plug Second pic is the CDI - move the green wire over one pin to the other ground. Not sure if this is really important or not. Black/white kill wire isn't connected to anything. I believe this is "ground to kill", but there's no spark with it ungrounded or grounded - so I don't think this is the culprit. Third pic is the rectifier - all the wires match up. I did pull a black wire out of this connector from the harness side. Figure there was nothing on the rectifier side for it to connect to, so why have it. Fourth pic is the coil - Black/yellow from the CDI and a ground wire for good measure, even though this should be grounded through the chassis.
Stator measure good per a youtube video I watched.
Engine cranks very well when hooked up to a battery through the starter solenoid. What in the heck am I missing? Got to be something simple... Everyone says to leave the gear indicator unplugged, so I haven't done a thing with that. |
Thanks for posting the numbers - I'll skip gaga and go check those out!
None of mine ohm out within these ranges - am I reading the table right?
PCC sent a new CDI to me. Delivered today and I'll give it a try as soon as I get off work.
Fingers crossed this is the culprit. |
New CDI did the trick. Happy to report that we have spark and running engine!
The replacement is a different size, they must have sent the wrong one with the engine the first time. But, I will say that they were responsive and took me at my word that the CDI was bad when they sent the new one. |
