12-11-2012, 05:19 PM | #1 |
150cc dirtbike chokes out
starts up first kick idles good right when you start off it wants to go then bogs out. if you give the throttle just a tiny bit itll slowly accelerate till higher rpms then bogs out so you can get goin a little bit just by shifting early but cant get a good deal of speed going.
cleaned the carb even though it was clean. airscrews omost all the way in. read http://forums.atvconnection.com/chin...-sunl-etc.html said something about an e chip in the carbu. you guys think this is the case? and how hard is that to do? |
12-11-2012, 05:21 PM | #2 |
its also around 30 degrees F here today so its pretty cold out.
12-13-2012, 12:11 AM | #3 |
This bike? http://toronto.kijiji.ca/c-cars-vehi...AdIdZ439388502
At this temp choke ON need. Valve clearance within limits? Useful materials for this pushrod 150: Carb: http://www.lincolndod.co.uk/PZ%20Car...g%20Manual.pdf Generic: http://hondacg125.awardspace.com/ Shop Manual: http://uploading.com/files/7985bmfe/ |
