Battery
Hello I have a 2006HI Bird 250st the battery is bad and I need a new one but the one in it does not look like the right one. can someone help?
Just measure the battery box you have and head to Walmart. Their AGM batteries are pretty good.
Thank you for all your help will need it for my other one to its a
KASEA Skyhawk 250 I don't think the motor on the Hi bird is a 250 any way to tell? |
Sure. Tell us the numbers that are stamped on the engine, near the shifter.
they are 167mm then on the bottom is 86601040
67 means 67mm bore, and the MM means motorcycle, 250cc. That doesn't actually mean that you have a 250cc bike, because the chart jumps from 200 to 250; manufacturers tend to round up.
The actual displacement will depend upon the stroke, and your engine is likely to be either 223 or 229cc.
Hey thanks trying to find a headlight and a fuel tank and a service manual for this to. I don't know why but he too the rear brake caliber completely off even everything to the brake pedal arm nothing is there lol. So I am going to need some info to get this working right.
