2006 lifan gy200 wiring help
Hi i am new to bikes all together and i am wanting to completely redo my whole wiring harness and simplify it as much as possible. As of right now it is not running (it died while riding and never would start again). It is both electric and kick start but if possible i would like to convert it to kick start only and also get rid of horns lights etc. Any help would be amazing ive looked all over the internet with no luck.
Thanks |
Do you have any idea why it currently isn't starting/running? Do you believe it to be an electrical issue? Did you turn the bike off with the kill switch?
Welcome!
X2 on Adjuster's questions. I'd get it running before trying to alter the harness.
The bike shut off while riding and never started again after looking I noticed the cdi appeared melted and I was getting no spark even after replacing cdi
The bike shut off while riding and never started again after looking I noticed the cdi appeared melted and I was getting no spark even after replacing cdi also I would like to know if I can make this bike work without a battery
Check source coil's ohm reading. http://www.dansmc.com/electricaltesting.htm
Any idea if I can wire it to run without a battery or wire it to be kick start only
If it's the same as my 07 Lifan 200 GY5 it will run without the battery and all the lights will still work.
I'm sure you could, but I would never give up the magic button.
How would I go about wiring it for,kickstart only. Any,and all info is much appreciated
#12 | |
--- Unplug those unnecessary. The cdi principle as #6 . The RiGHT part from alternator is NOT NEED in no battery mode. ![]() ![]()
I believe it is a faulty wiring harness. On the,lifan allgrounds come together under the seat.
