Old 04-18-2015, 01:14 PM   #1
JPG1911   JPG1911 is offline
JPG1911's Avatar
My 1980 HD Sportster
Last June I was able to help out a friend who needed to put some cash together quickly. He sold me his 1980 Harley Davidson Sportster 1000 XLH for a song. The bike had been stripped down and rebuilt and modified by my friend and his father(who owned a Harley shop in Va at the time) in 2000. They put about 4000 miles on the bike over the next few years, and it was parked in a shed in 2007 and forgotten about.
By the time I found out about the bike, time and chlorine fumes had taken their toll - the shed which housed the bike for 7 years also happens to be a pump house/pool shed full of pool chemicals
Here is a pic of the bike from the first time I saw it
Every bit of chrome on the bike was flaking, rusted, or gone. All of the aluminum bits were heavily oxidized and/or pitted. Every surface that didn't have good paint left on it was rusted. This was going to take some doing.
Undaunted, I picked the bike up and took it to a good friend's house to begin resuscitating it in his garage. Here she is with the first layer of dust wiped off
I didn't care one little bit about the chrome and paint. I planned from the get-go to achieve the "murdered out" look and paint mostly everything black - I have nothing against shiny bikes, they're just not for me.
Taking stock of everything, I decided to focus on getting the bike running and riding before cosmetics. There would be some things that got sanded and painted along the way, simply because I had to remove them anyway, but the plan was to get it running and ride as much as I could before it got cold, then strip it down over the winter and paint or powder coat everything and make some modifications. On the day I got the bike, I drained and refilled fluids, put new spark plugs in it, poured seafoam in each gas tank, hooked it up to my truck with jumper cables, sprayed a little starting fluid in the carb, and got her to fire right up! Unfortunately, that was the most action the bike saw for a few more months. I took stock of everything that was needed, and as is usually the case, it was a lot more than I had originally planned on. I began to order and collect parts as my budget allowed. It was late fall/early winter before I was able to get enough items together to really do anything to the bike.
The tires were badly cracked and dry rotted, so they were the first major item to be replaced. I decided to attempt replacing them myself. I am very familiar with replacing car and truck tires, and have used many different tire machines, but replacing motorcycle tires with nothing but a set of spoons proved to be quite a task! I successfully replaced the front tube and tire by myself, but no matter what technique I tried, I could not get the back tire off the rim. I eventually gave up and cut the tire off with a sawzall. The inside of the rim was badly rusted. I spent 4-5 hours scouring the inside of it with a rotating brass brush chucked into my drill, various types and grits of steel wool, scotch-brite, and sandpaper. My initial plan was to sand blast the rims and paint them, but I couldn't find anyone with a blast cabinet big enough to handle the wheels, and the only local shop that does it wanted way too much money for their services.
We did not have a proper motorcycle lift or jack, so we had to get creative when removing wheels
By the time I got around to replacing the tires, I had sanded and painted many items with either black plastidip, or hi-heat flat black BBQ paint. I also installed some 12" rise mini ape hangers and a new bar clamp.
The transition from motorcycle to "Murdercycle" had begun.
That's all for now. I will update this thread more as time allows. I still have some pics to find and upload to photobucket, and lots more of the process to share. She is a continual work in progress, and I am happy to share the progress here!
In the next post, I will detail all of the modifications made to the bike before she came to live with me, and how she got saddled with her current identity crisis - is that a Sporster, or a FLH???
2004 United Motors DS200 "Denise"
Be Dragonized!
Old 04-18-2015, 06:54 PM   #2
Thanks for starting this thread.
I like Sporties, and I'd love to have one. It's cool that yours is a 1000, vs 883, so it'll have a little more in it. Good deal on the forward controls; I can't ride a Sporty with mids for long.
I get the identity crisis; that fat bob tank certainly looks FLH-like. What is your plan? I'd love to see a peanut on there. Are you going to keep the front end or switch to a springer?
The finned side cover looks like it's begging to be part of a 48 look. Just MHO.
Old 04-18-2015, 10:39 PM   #3
cheesy   cheesy is offline
cheesy's Avatar
Nice start. I'd like to see how it turns out
I don't know enough about Harleys to be right, wrong, or indifferent. But I know improvising and like your work stand.
I know what b!t?h getting a tire off a rusty rim can be. This may, or may not, have worked in your case but was taught to me by another improviser in Maine. You need a 5 gallon bucket, two large c-clamps, and two 1x4 boards about a foot long. Place the wheel on the bucket and squeeze the tire between the two boards and c-clamps. Spraying the rim with PB Blaster MAY speed things up a bit. Anyway, clamp everything together as tight as you can, it may break right away or you may need to sit through a double feature but it will pop that bead.
If they were solid rims, I'd tell you to park your truck on the tire and go have a cup of coffee.
Cheesy
07 Ural Gear Up
79 Honda CX500
77 VeloSolex 4600 V3
73 VeloSolex 3800
Old 04-19-2015, 11:55 AM   #4
I wish I had known these tips on Friday, when I would have passed them on to my illegal Son. He was trying to remove the tires from his old Honda 750, and they've been on there for more than 20 years. He ended up using a reciprocating saw.
Old 05-31-2015, 02:38 PM   #5
JPG1911's Avatar
I too, resorted to a sawzall on my rear tire
The Fat Bob tanks have grown on me, and like the extra fuel capacity, it's nice to have 5 gallons
I have considered a springer front end, but I would really like to put a set of 39mm forks on it with full "tins" and the elongated headlight fairing a la the HD Fat Boy. I forgot where, but I actually found a full "Fatster" kit online that includes all the parts. I'd want it to be black of course, not chrome, so it will get powder coated when i get it.
Be Dragonized!
Old 04-19-2015, 09:49 AM   #6
katoranger's Avatar
I like that tank. Sounds like a great bike to make it the way you want.
Old 04-19-2015, 10:41 PM   #7
Thanks for starting the thread on this interesting project.
Old 05-31-2015, 02:42 PM   #8
JPG1911's Avatar
Bad news in sporty land. The transmission is toast. I have lots of pics and back story yet to post here, but every time I think about it, something pops up, lol. I sat down to make the promised update post, and I just got called back into work. I'll get some more pics and info up tonight. Off to work I go!
Be Dragonized!
Old 05-31-2015, 03:22 PM   #9
Is it a full unit motor, or can the transmission be separated?
Old 05-31-2015, 04:38 PM   #10
JPG1911's Avatar
It's an Ironhead, the engine and trans share a case. Extremely similar to the shovelhead motor except for theddisplacement, shared case, and it has parralel push rods vs the shovel's V configuration. I've already pulled the tranny and confirmed that it will have to be rebuilt or replaced. My options range from $400 for a used one to over $1200 for a built Andrews transmission. Since the motor is well built and significantly more powerful than stock, and I don't want to strip any more gear teeth( I sheared off 6) I'm going to resuse the trap door and shift forks, and replace all gears and shafts with Andrews parts. Should run me about a grand before I'm done. More info and pics when I get the kiddos in bed tonight.
Be Dragonized!
Old 09-28-2016, 06:12 PM   #11
Ariel Red Hunter's Avatar
Even thou I once owned an iron head Sportster, I'm by no means an expert on one. BUT a bar I used to hang out in had a half dozen Sporty riders many of whom had blown a transmission. The story they told me was this was caused by full throttle clutchless upshifts. I said you guys do full throttle upshifts on pavement? The answer was "Well, by closing time, we'd be pretty well Yacquied up on H-D Lemonade ( a stomach etching concoction of vodka and Wild Turkey, plus a little lemon juice) and have to drag race home. The fastest way to shift is not to bother with the clutch If the motorcycle God's were smiling, everything lined up, and you'd be good to go. If not, a stripped transmission." He also told me that shifting that way over stressed the gears, and they would "puke" a tooth or so, somewhere down the road.
Old 09-28-2016, 08:59 PM   #12
Old 10-16-2016, 01:46 PM   #13
The Sportsters transmission was very stout. You had to really abuse it to strip gears. How stout? Well KR's were routinely shifted this way on dirt race tracks at the start of each race. It was fun to watch them, because they would just touch the kill switch during every upshift, 2 foot long flames coming out of each exhaust pipe. The sportster of those days was a K model, or a KH (883 cc) with overhead valve heads attached to it.
Old 05-31-2015, 10:15 PM   #14
JPG1911's Avatar
Backing up a few posts, I promised more pics and a better description of the mods and current status.
My friend wanted a FLH or Road King type big twin cruiser, but his dad had this little stock sporty at his shop, so they tore it down and began to mod it into a more laid back cruiser than a mid-control racer.
They started with the engine. The jugs were bored 0.040" over and honed. Then, new forged Weisco 10:1 pistons and new wrist pins and rings were fitted to the factory rods. The bottom end was deemed good, so the cases were not split. The heads were sent to specialist with a flow bench and given a full port & polish, as well as decked 0.010" and lapped. New stainless steel valves were fitted into the stock bronze valve guides and new springs were installed with the factory rockers and rocker boxes. 1980 was the first year of electronic ignition on the sportster and it was still quite buggy, so they yanked it in favor of a more traditional breaker point system. They installed a high output accell ignition coil and installed Andrews PB+ grind cams, and capped it off with a S&S Super-e shorty carburetor and drag specialties 1.75" diameter drag pipes with baffles that are more for the inspector to see than to actually serve a functional purpose. The transmission was left stock - more on that in a minute
Next they installed the forward controls and dual Fat-Bob tanks. The fenders and tanks were hand painted with a wonderfully nostalgic crinkle finish blue paint job by my friend's uncle. I have since learned that the pearl effect in this type of paint application is often referred to as a "saran wrap job" and is accomplished by laying plastic cling wrap over the wet paint and ripping it off swiftly. Pretty neat
This photo shows the effect pretty well if you zoom in on the tank
They then fitted a very nice Corbin 2-up saddle and sissy bar, custom mirrors, grips, gas caps, and an 1960's reproduction Caty-Eye dash with single digit speedo. The suspension mods consisted of Progressive rear shocks and a front end from a newer sporty with dual front disc brakes.
The bike was dumped on it's right side twice, but sustained little damage. When I got it, the rear master cylinder was leaking. I wonder why...
<sigh> back to work I go... I will add more later
Be Dragonized!
Old 05-31-2015, 10:46 PM   #15
Adjuster's Avatar
I like the dog. LOL
