Old 04-12-2016, 08:36 PM   #1
Kneedeepinit   Kneedeepinit is offline
Kneedeepinit's Avatar
Rim / tire question for hawk 250
if I purchase these tires, http://www.amazon.com/Shinko-Series-...iglink28144-20
Would I need different rims or would I be able to use the factory hawk rims?
Sorry if this is a stupid Question. I'm learning as I go.
Old 04-12-2016, 10:08 PM   #2
lee47512   lee47512 is offline
Yes on the front is a 90/90-21 tire in other words tall and skinny that would be like putting two back tires on. I have the same ones on mine there a lot better for blacktop then the stock tires.
Lee
2014 powermax 150.
2015 Hawk 250.
Poop happens
Old 04-12-2016, 11:39 PM   #3
newrider93   newrider93 is offline
newrider93's Avatar
Did you buy both or just the rear? The link you posted is just the rear tire. You can use the same rims with the 120/80-18 and 90/90-21.
Old 04-12-2016, 11:52 PM   #4
I did not purchase anything yet was just looking around trying to get an Idea.
Old 04-13-2016, 07:45 AM   #5
kohburn   kohburn is offline
kohburn's Avatar
I don't think that is what you meant to say since one uses an 18" rim and one uses a 21" rim
-whatever you do, just be awesome.
- 2008 Kawasaki Versys
- 2016 CSC TT250
Old 04-13-2016, 08:20 AM   #6
Sorry let me be a little more clear. I'm looking around for street tires that would fit both rear and front rims of my hawk 250. I know I posted only the rear tire link but that is the only one I have found so far. I don't know that much about dirt bike tires (or any tires for that matter) and sizes so any help is welcome. So any links to good street tires both front and back that would fit the rps hawk 250 please feel free to post them. I believe i would need new inner tubes as well so I wouldn't mind a link to that as well. Thank you everyone for your help as I said I have a lot to learn lol.
Old 04-13-2016, 08:50 AM   #7
I would not recommend the Shinko 705 for your rear tire. The size 120/80-18 tire is designed for a size 2.75 rim, which is much wider than your rear rim.
http://www.shinkotireusa.com/tire/705-series
I recommend the following tires for your motorcycle. You should be able to use your current inner tubes with these tires.
Shinko 244
Front tire: size 3.00-21
Rear tire: size 4.60-18
Shinko 700
Old 04-18-2016, 08:59 PM   #8
79elco   79elco is offline
Tire clearance
Will the Shinko 244 4.60-18 clear the chain on the Hawk? I see the stock knobby is very close.
Old 04-18-2016, 09:06 PM   #9
I don't own a Hawk motorcycle, so I can't be sure. However, I would be surprised if the size 4.60-18, Shinko 244 tire did not clear the drive chain on the Hawk.
Old 04-18-2016, 09:26 PM   #10
Thanks Spud. I will take your wisdom under advisement. I guess I could get out my digital caliper and do some figuring.
Old 04-18-2016, 10:53 PM   #11
fishtime9   fishtime9 is offline
I would highly suggest just to buy a pair of shinkos. However, you could also do the ninja rim swap modification (Please follow my threads or message me, and i will make sure to help you out with this one ).
Old 04-26-2016, 05:49 AM   #12
bogieboy's Avatar
Shinko 244
Shinko 700
spud, just as a heads up I have 2000 miles on my set of shinkos on my bike, with a 110/80-16 on a 2.1" front and a 130/80-16 on the 2.35 rear with no problems.... is it ideal? probably not.... but it hasn't caused me any trouble either.
Old 04-26-2016, 07:03 AM   #13
That's good; I'm glad you are enjoying your tires, and they are working well for you.
I do encourage you to regularly inspect the inner tubes for wear caused by friction/rubbing with the sidewalls of the tire. If you notice any thinning/blemishes on the inner tubes, replace the inner tubes before you get a flat tire, which usually occurs at the most inconvenient time.
Old 04-19-2016, 12:15 AM   #14
mq1991   mq1991 is offline
$33, good deal?
http://www.ebay.com/itm/Shinko-244-D...xWHthw&vxp=mtr
Old 04-19-2016, 01:30 AM   #15
Originally Posted by mq1991 View Post
Yes, that's a good deal.
If you are going to buy two tires, or otherwise spend $75, you can get free shipping from the following vendor.
https://www.rockymountainatvmc.com/p...ual-Sport-Tire
