08-07-2016, 08:51 PM | #1 |
2010 Gio Rebel T3 - Ball Joints
Hey guys! New to this forum, i recently bought a used 2010 gio rebel t3, 200cc.
After riding for a bit i noticed significant play from both lower ball joints, went on to figure out that these ball joints are apparently a part of the control arms themselves. Unfortunately i cannot find the lower control arms for the t3 absolutely anywhere, any recommendations? Thank you! |
08-08-2016, 11:48 AM | #2 |
Welcome!
With some generic eBay searches (like atv ball joint or atv arm), you might get lucky. Otherwise, you might need to grind those joints out of the arms and install replacements that bolt in.
08-08-2016, 12:57 PM | #3 |
i've tried the above generic searches to no avail, i think I'll have to resort to grinding the joints out of the arms at this point
08-12-2016, 09:04 PM | #4 |
I suppose i would grind off those welds on either side, take out the joint and install a new one? Any idea where I can find a bolt-on for this? thanks!! |
08-19-2016, 11:20 PM | #5 | |
http://www.schrems.org/product_info....ducts_id=37978 from A quick google image search for A arm ball joint
08-20-2016, 09:28 AM | #6 |
Ball joints
Yes they are welded in.......my shipper in China says $110.00 USD for the set....that is cheap....pm me dhand
09-26-2016, 01:10 AM | #7 | |
You can see the welds which have been painted over orange around the joint. You're seeing bare metal because the bottom has been scratched up on gravel and whatnot. |
04-30-2017, 10:41 AM | #8 |
Throttle Cable
I'm in need of a new throttle cable for this quad any thoughts?
08-12-2016, 09:37 PM | #9 |
There is probably no bolt on ,but might get lucky with a snap ring one .Since you have a gio ,I will assume you are in Canada ,you might try looking them up in the Royal distributing catalogue ,but you will need to measure yours up first .
08-13-2016, 07:35 PM | #10 |
no luck with them unfortunately
08-13-2016, 08:10 PM | #11 |
What are the dimensions of the old joints ?
08-18-2016, 12:26 AM | #12 |
gio t 3
Hello.. I am a dealer for gio so I have sent them an email and will let you know if they have them or what to do... I have switch ball joints on a colster before as they say.. grind the out and re -weld them... $$$$ but without it it was worthless.. let you know tomorrow night .... where are you located?????????
08-18-2016, 08:22 PM | #13 |
A ARMS from GIO
You are right... no a arms from GIO anymore... the best you can do is to find some ball joints that are about the size of the balljoints once you remove them... have them reamed out and welded into the arms... that is the bad thing about buying some models of GIO,, They quite making the parts and carrying stuff... if you google the maker on ALIBABA or MADE IN CHINA... I think easy vechicle company... they can sent you the parts.. of course they will charge you... and ship DHL it might still be cheaper... I think I paid about $100.00 labour and that was cheap... and them the ball joints...... there is no real way to match them up with some other brand... to much work.. good luck
08-19-2016, 11:14 AM | #14 |
With good measurements of the stock ball joints, it shouldn't be that hard to find bolt-in versions with a similar diameter. it would then be a matter of carefully grinding the old joint out and bolting in the new one.
08-19-2016, 12:23 PM | #15 |
gio t3
does this look like your atv??
