09-16-2016, 09:10 AM | #1 |
TT250 CG Motor Clutch
Why does the clutch on my TT250 feel so pathetic. Forget about fanning it or giving it any abuse, it just chatters and slips. Is this a result of building a 230cc motor around a clutch designed for a 125? Are there some decent japanese/honda clutch plates and springs that can beef it up? Is the basket strong?
Just to continue this rant, the transmission doesn't shift as cleanly as a japanese transmission would. Should I just STFU and live with my bargain chinese ride? |
09-16-2016, 09:36 AM | #2 |
Mine chatters when starting out in first gear all of a sudden, does not feel how it did when I first got it, starting to get a little concerned myself actually. All the other gears feel OK but there is a noticeable chatter/clunk when starting from a dead stop now.
2005 CBR600RR
2016 CSC TT250 Coming Soon |
09-16-2016, 09:51 AM | #3 | |
How many miles do you have on it? What oil are you running? My CG clutches have been pretty particular to the oil it drinks. 15W-40 diesel is always a good choice. I'm a big proponent of synthetic but the CG's seem to actually like dino oil better. The clutch quits chattering. You'll also need to change the oil quite frequently in the first 2500 miles or so. When it starts to chatter, change it. It's only a quart. It will get better with miles too.
09-16-2016, 10:01 AM | #4 |
I went with 15-50 synth on my first change. I'll switch back to Rotella or Valvoline non-synth for the next one. Have about 500 miles on her...
09-16-2016, 12:02 PM | #5 |
This could be your problem. What was the oil you used?
09-16-2016, 11:01 AM | #7 |
I do have a bit of chatter as well in first gear only from a stop and gets grabby, not smooth. No issues with chatter in other gears. Generally only when the bike is hot. Get's a bit harder to shift when at times when hot as well. Adjusting the clutch cable seems to mostly cure the issue. I think since the clutch cable runs down by the exhaust it tends to get quite warm and sloppy causing the chatter.
I've got 1400+ kilo-miles and another 100 or so actual miles on the new tach cluster. Running Rotella 15-40 non synthetic (what I've used in my KLR for years with no issues) and on my third oil change. Good point on the engine mounting bolts Mudflap. There is certainly noise from the clutch. Rojo
'15 RX3 (Rojo's) '15 RX3 (marzhere's) '16 TT250 |
09-16-2016, 11:51 AM | #8 |
There is no noticeable chatter on my Lifan, which uses a similar motor and identical clutch. Ensure that the cable is properly lubricated (I like Maxima Chain Wax on cables) and take the time to adjust the cable properly.
09-16-2016, 11:53 AM | #9 | |
As Rojo said it is more prevalent when the engine is hot and in our case only from a stop in first gear. Even after my oil change it has remained.
2005 CBR600RR
09-16-2016, 12:00 PM | #10 |
What type of Carb and settings (jets, needle clip, etc.) do you currently have? Sprocket sizes? Clutch Freeplay Set? Valves adjusted recently?
Would be a few questions I would ask to help narrow down if it's a "Power Delivery / Chatter issue" or an actual "Clutch / Spring / Chatter" problem
09-16-2016, 12:11 PM | #11 |
Mine is perfectly smooth, both clutch and trans. I even start out in 2nd frequently as 1st is so short it's pointless unless I need to jump off the line quickly. But my mileage is much lower than yours so maybe it's just a new thing.
Make sure nothing's loose or tweaked; engine mounting, sprockets, etc. It could be the oil too. I've had lots of bikes and some of them are pickier than others. I've even found where two different bikes of the same model have different preferences. |
09-16-2016, 01:46 PM | #13 |
Mrs. 2LZ does it on occasion from a start but only after it's sat for days at a time. Q and the RX3 have done it also. Q, not so much. I put in some other oil (can't remember right now), it squealed and chattered a little, so I drained it out right away and put in the 15W-40. Problem solved.
Seems all three have done it after it's sat for a while. My X-Moto would jump and stall when I put it in gear after sitting for a few weeks or a month but once the clutch was broke loose, it was fine.
09-16-2016, 04:10 PM | #14 |
most clutch chatter is from the fit up of the
plates fiber and/or steel on the clutch basket or hub.. poor machineing with tolances to big... cold motor the oil is thicker so it helps stop/hide the chatter... why some motors will do it & others don't... where the clutch was machined in the production run as machines setting do change , cutters ware etc.. Ie... in a production run of 300 componets yer exspect the first units to have a tighter tolance just after the machines had be set up than the last... also how much care the guy setting the machines takes... Maybe another possabiliy is the amount of lash in the gears between the crank & clutch basket... to much movement can cause the basket fingers to tooth... My XT660 has a anti shudder ring in the clutch stack to stop chattering.. .. ...
09-16-2016, 07:51 PM | #15 | |
