10-12-2007, 12:41 AM | #1 |
Kazuma 110 mod.
Well, it finally happened, The little quad that could has died. Loss of compression. After checking the price on a new head(intake valve has failed) at over 100$, I've decided it's mod time. I have found a Lifan 125cc motor for 150$ picked up. I picked up the motor and will be slapping that little puppy in the little beast and adding a clutch lever. I lose reverse, but gain a gear. We'll see how it goes. As the motor is geared for a pit bike, the tranny should be set up for a 12" rear tire. Might be a bit low as the rear tire on the quad is a bit smaller, but we'll see. For 150$ I'll be happy to see it move again.
2009 XR650L Big Red Pig Tusk bar risers 2007 X-Moto(Jetmoto) GY250 --mods--- 15/40 sprockets UNI Pod Filter 2007 Shineray TMS 200XYi--Betsy Betsy Mods:______________________ Acerbis DHH headlight FMF Powercore pipe Uni Pod Filter |
10-15-2007, 01:16 AM | #2 |
the 125cc motor in my pitbike is pretty fast, i'm sure that new motor will make your quad fly!
it probably uses the same chain size, so you'll probably have a relatively easy time getting it set up i hope. keep us posted! |
10-15-2007, 11:55 AM | #3 |
Everything went suprisingly well. The motor is in, just awaiting the correct sprocket as Lifan has a bit larger output shaft diameter. As luck would have it, it's the same as my bike which made it easy.
Believe it or not it uses a 520 chain.
10-15-2007, 12:07 PM | #4 |
Incidentally I would have ordered the sprocket from Endless Journey, but As I live in a small town, I like to support my local bike shop whenever possible.
