OIL FYI
I know oil has been talked about a lot here but I just wanted to let you know about my experience. I’ve been running Rotella 15w40 now since I got my 07 Lifan GY5 with good results. After 4000km I decided to try a synthetic. I tried a quart of the Walmart full synth 10w30 after reading another member had good results with it. The first thing I noticed is the clutch slipped a little under heavy load until the motor got nice and hot, which is not good. It slipped even after a clutch adjustment. Other than that it seemed the motor ran a little smoother especially at take-off/low rpm’s. This could just be due the thinner weight or the fact it’s a slipperier synthetic oil. Either way I dumped the synth right away and filled her back up with Rotella and the clutch slip was gone. I think I will be sticking with regular dino oil from now on just to be safe.
Bone stock 2007 Lifan GY-5 |
Yeah, that was me. My Roketa clutch slipped since day one in 4th and 5th when the oil was cold. I have noticed no better or worse clutch action with the 10w30 synthetic or any of the other types I tried. I plan to upgrade to HD clutch springs over the winter while I have the bike apart to go through it. Bummer it didn't work out for you since, as you mention, the lighter oil really wakes up these little motors. My next oil change I am gonna try a 5w20 just to see if it continues to climb in power. In my Roketa the difference between a 20w50 and the 10w30 feels like twice the HP, no joke.
Perpahs its the Wal-Mart brand oil that is the problem. I've been running Amsoil synth motorcycle oil with no slippage at all.
Frostbite "The beatings will continue until moral improves" |
#4 | |
China bikes should LOVE WalMart (ChinaMart) since most everything in WalMart is from china.
![]() I've read that synthetic is better but not to use it until an engine is fully broken in. It (synthetic) has worked well in my tracker since the first oil change at 3000 miles and has been in it ever since. I doubt I'll run it in our bikes I'll just be sticking to the crude old dino oil which in my opinion better suites our bikes. ![]() |
Im due for an oil change after i replace all the bolt the hold the back sproket on as they sheared off. At the moment i am using 20w 40 and have done about 1300km should i change to something else? or stay with what i have
My Roketa clutch would slip at times too, didn't matter if I was using dino oil, or Amsoil. A clutch spring kit took care of that. Simple & cheap upgrade.
2005 RSX-200E 2004 Suzuki Eiger 1999 Arctic Cat 250 1977 Kawasaki KH400, aka Green Ripper |
synthetic vs coventional oil
I used to read every popular motorcycle magazine out there avidly. cycle world, motorcyclist, and cycle, and there was a article in thier on oil, and they tended to want to steer away from synthetic oil designed for automobiles, something about automobiles having no wet clutch system, and the oil being to slippery. Now synthetic oil designed for a motorcycle was fine it had the right properties to obtain good friction.
Im not saying automotive synthetic oil is bad, it is good but may not have anti slip properties for a wet sump friction type clutch in a motorcycle. This is what the article said not me. Good luck |
#9 | |
Re: synthetic vs coventional oil
#10 | |
Oooo if it fits add it to the parts cross-reference section.
2009 XR650L Big Red Pig Tusk bar risers 2007 X-Moto(Jetmoto) GY250 --mods--- 15/40 sprockets UNI Pod Filter 2007 Shineray TMS 200XYi--Betsy ![]() Betsy Mods:______________________ Acerbis DHH headlight FMF Powercore pipe Uni Pod Filter |
I broke down and bought the synth, moble 1 I think, for motorcycles only. 13$ a litre stuff. Most expensive in Canadian tire. 5 more than normal full synth as a gift for making it back from Quebec. I'll never put anything else in any bike I ever own. Clutch stopped slipping as much. Rods are quieter. I wish I forked out more earlier. JMHO :roll:
IronFist ___________________________________ The "chain" of command is used for beating spammers. ___________________________________ |
The number for the clutch spring kit is:
Parts Unlimited number 2012-302 Barnett number MT-15-4
#14 | |
#15 | ||
2008 Jonway MC-70-150 2007 Roketa DB-07B (RSM-200E) 2006 Roketa DB-07A (RSX-200E) 1995 Kawasaki Concours (ZG1000) |
