Big bore
Has anyone put a 50mm big bore on a taotao thunder with a gy6 I will be doing it in the next few days just looking for someone that has if I run into any problems
2016 TT250 2014 NSS300 FORZA 2014 UN200 BURGMAN |
Research resource . . enhanced odds of bearing failure.
If this style muffler. . only remove top ear bolt, then pivot on loose bottom ear bolt, after removing 2 bottom head exhaust pipe nuts. Suspend muffler from upper frame with a cord. During assembly, install top and bottom cooling shrouds prior to muffler attachment. |
Jets and idle
I put in the 80 cc kit runs great but hard to get started and idle is bad and it is needing more gas I have put a cone filter on as well but still have stock muffler and suggestions
Pilot and main jet sizes?
If using the stock head which has around a 5cc combustion chamber . . . 39mm bore (50cc) = around 10:1 static compression ratio 44mm bore (63cc) = around 12.6 static compression ratio . . resource 47mm bore (72cc) = around 14.4:1 static compression ratio . . resource 50mm bore (81cc) = around 16.2:1 static compression ratio 52mm bore (88cc) = around 17.6:1 static compression ratio For comparison . . . Sym 50 11.8:1 Honda Ruckus 50 11.9:1 Yamaha Vino 50 12:1 Static Vs. Dynamic Compression Ratio 1 teaspoon (4.9 cc's) in a stock 139QMB cylinder head . . . ![]() ![]() Last edited by tortoise; 12-14-2016 at 12:15 PM. |
