02-13-2017, 08:46 PM | #1 |
Cross reference ?
New Hawk250 owner by Thursday hopefully here.
Do you guys have a cross reference for parts on the hawk . Like oil filters , sprockets, bars , tires , brake pads , and ect. Sure would be cool if such a list existed . Most inportantly is oil filters as I will need replacement by Friday am as I plan to break in motor Thursday nite .
Living life to the fullest to avoid regrets later ,,,,or I am a complete loon ! Either way I am good |
02-13-2017, 08:57 PM | #2 |
the hawks oil filter is reusable as it is just a wire screen that is accessed on the left side of the engine. also engine oil is 1 quart not 1.6 as the manual says.
02-13-2017, 09:05 PM | #3 |
hadnt needed pads yet but i think these may be the same. http://www.cscmotorcycles.com/TT250-...AKES-s/368.htm
first thing you will need is a set of jets to jet the carb as it comes really lean then maybe a 17tooth front sprocket if your doing much road stuff. front spocket https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 rear sprocket https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 jets https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 tag solution https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
1991 harley heritage softail classic 2016 hawk kaw h1 400 tripple 13' long chopper in progress 2009 johnny pag bar hog 2004 hd electra glide ultra classic shriner edition 1997 harley davidson 1200 sportster 1972 harley davidson amf sx250 Last edited by timcosby; 02-13-2017 at 09:11 PM. Reason: added some more shit |
02-14-2017, 12:02 AM | #4 |
This site is getting bigger and bigger over the last year http://hawk250.com/
Use generic search terms like Chinese motorcycle on ebay or Amazon. There's tons of stuff out there and cheap so you can play all you want without breaking the bank.
02-14-2017, 09:10 PM | #5 |
Wire screen oil filter is a bit spooky , just sayin.
for all the replies . They will help. The tip about generic search is super helpful . Looking forward to sharing pix of the journey me and this little bike will be on . Looking like tomorrow it will show up at my workplace . Thoughts on rejetting the orginal carb or just buy a Mikuni right away for ya all ??? I most likely will buy a pipe right away and rejet at that time . Thanks again everybody .
02-14-2017, 10:39 PM | #6 | |
This might be his first one...
02-14-2017, 10:33 PM | #7 |
oil change is More or less the same as http://chinariders.net/showpost.php?...61&postcount=3
02-16-2017, 06:05 AM | #8 |
I had to leave out the rubber on the front fender and use a washers to hook up mine.
02-16-2017, 07:47 AM | #9 |
Mine had that same wrinkle in the seat but after I had the seat out where the sun could hit it the wrinkle magically disappeared. As far as carburetor I just rejetted the stock carb with a 115 but I gutted the cat out. a 110 jet is a good start if you have the stock exhaust. Remove the cap over the idle mixture screw and reset it to 1 1/2 turns out as a starting point. Shim the needle with two small thin washers too. After doing these mods I can start it without choking the carb on warm days and will idle without having to fool with the idle speed screw. On cold days I can start it on half choke and will idle. These bike are fun to play around with and customize to your liking. And most important to run it on the oil that came with it. Run it long enough to warm it up and suspend any metal that was left in there and drain it. Use a non synthetic oil for the 1st oil change so the motor can break in and seat the rings. Put about 200 mile then change again.
02-20-2017, 08:07 PM | #10 | |
All info is greatly appreciated . I will share any and all I find along the way also.
02-20-2017, 10:20 PM | #11 |
Not sure, you may want to verify. I think the speedometer has a mph overlay to make the dial indicator more or less accurate (). Meanwhile, the Odometer gear is still calculating kph.
Get rid of it asap, best mod you can do. The mjstef digital cluster is accurate, fast easy install and truly plug and play. Around $100.
02-20-2017, 11:20 PM | #12 |
Member mjstef sells a digital cluster. One of the Motocheez videos shows him installing it.
02-21-2017, 07:40 AM | #13 | |
