Old 03-04-2017, 09:58 PM   #1
DatBrooklynBoy   DatBrooklynBoy is offline
Supermoto wheels on Hawk 250?
I just ordered a Hawk 250, and was thinking about buying 17 inch rims with spokes and lacing it up with the oem hubs, i was wondering will 17 x 4.25 rims with 140/70/17 tires clear the rear? i appreciate the help in advance, i also apologize in advance if this information is already on here i searched but could not find the answer.
EDIT: What kind of tools will i need to assemble everything?
Old 03-05-2017, 12:00 PM   #2
Ariel Red Hunter's Avatar
My first thought is if you want 17 inch wheels, you should have bought a different motor-cycle. Maybe a Magician which come stock with 17 inch wheels (I think), and several others. I do not believe a 140/70/17 will clear the rear chain. The rear chain barely clears a 4.10 X 18....ARH
Old 03-05-2017, 12:09 PM   #3
ben2go   ben2go is offline
I would look at 17x3.5 rear with a 130/70 and 17x3.0 front with a 110/70. These sizes work on a DR650 with 17-inch wheels. The DR650 runs the same size OE tires as the Hawk, so they should work without interference.
Old 03-05-2017, 12:24 PM   #4
you guys dont know how much i appreciate the reponses, i have seen numerous members on here with 130 wide street tires in the rear on 17s so i definitely know 130s are possible, i was just wondering is the 10mm difference really the deciding factor of whether not the tires will clear the chain and swingarm? Can i still go 4.25 rim in the rear with 130 tires? Im asking because someone is selling a set 3.5 rim in the front 4.25 in the rear. of course i would have to buy spokes separately and then lacing them on the stock hubs.
Old 03-05-2017, 12:30 PM   #5
The 4.25 is a little wide for a 130. I'm not sure if a 140 will fit the bike but it will work with the 4.25 rim.
Old 03-05-2017, 12:46 PM   #6
whats the downside of putting a 130 on a 4.25?
Old 03-05-2017, 02:12 PM   #7
Yes. A 130 is 5.2 inches wide. Imagine trying to get a 5.2 inch wide tire to work where a 4.10 tire has only 1/4 inch clearance. Still, if you intend to do this, the guy at Britannia motorcycle has a whole series on making a B-25 BSA into a trials bike. One of the chapters shows the easiest way to spoke a wheel/hub combination of any I've ever seen. He's a little difficult to understand, as he's originally from Yorkshire (I think), England. If you liston to him as he builds a wheel a couple of times, it will become very clear....ARH
Old 03-05-2017, 03:36 PM   #8
Thank you, now with all this being said, has anyone put a 140 rear tire on their hawk successfully? and if you did was any modifications needed?
Old 05-20-2017, 01:25 PM   #9
JeremyC   JeremyC is offline
OP, if you end up doing this, I'll buy your old rims and spokes!
Old 05-23-2017, 11:13 PM   #10
RogerWFarrier   RogerWFarrier is offline
RogerWFarrier's Avatar
Since the majority of my riding is on the pavement I'm planning on buying an extra set of wheels and running Bridgestone Battlax B-45's on them and then swapping to more aggressive tires when I go off-road. In Super Moto they have a Sportsman Class where they run the stock 21 inch front wheel with street tires so that's where my primary motivation comes from.
http://www.americanmototire.com/cata...roducts_id=690
http://www.americanmototire.com/cata...roducts_id=698
2016 CSC TT 250, 17/40 sprockets, JT 428 chain, Stock Keima carburetor with needle raised 1 notch and 115 main jet. Modified stock exhaust, Tachometer/Digital cluster upgrade. LED headlight, Superbrightleds 1157 Tail light bulb, Shinko 705's 90/90-21 and 120/80-18.
Old 05-24-2017, 01:28 AM   #11
The BT45 is a great touring tire. Decently grippy and great in the rain. They also last a long time, snd that is on much heavier bikes. It will probably outlast the bike lol.
Old 05-24-2017, 02:37 AM   #12
pete   pete is offline
pete's Avatar
Wonder if the Hawk will have enough power & weight
to get them to work.... could always be like riding on cold / just warm tyres...
09 XT660R ...
06 TTR250 ...
80 Montesa H6 125 Enduro...
Current resto projects..
81 Honda CT110...
80 Kawasaki KL250A1...
http://www.remotemoto.com/
E-mail... xtpete1@gmail.com
Old 05-24-2017, 02:15 PM   #13
I've had the BT45. They should perform fine on the Hawk for road use as they aren't an overly stiff "heavy duty" cruiser tire. They are actually quite grippy for cornering. If I were, for whatever reason, going to make my bike a pure street only machine, this is definitely a tire I would consider for commuting duty.
