Rear rotor bolt mush-any known alternatives?
Title says it all.
Anyone know of replacement rotor bolts that will fit, other than stock? Thank you in advance for whatever useful info you may provide
There is someone that I must meet again. And until that day…not even Death itself can take my life away! |
I would look on the CSC website for the part: They usually list the metric specification which means finding subs is easy.
It's the width and depth of the shoulder as well as head diameter that matter. All their info has in the description on their page is "Screw M8X16"
#5 | |
Spud, wish you had found them last summer....
![]() ![]() ![]() Another tip for trying to avoid stripped bolt heads: Besides using a heat gun to soften the thread locker, use a hex wrench or socket that has the tip squared off. I used a grinder to square off the crown on the hex socket. That allows the hex to seat deeper into the socket head. Even so, when torquing the new bolts, I could feel the socket head on the bolt starting to strip. ![]() ![]() jb
#7 | |
I bought a 3/8 drive set from Autozone (Duralast I think) and they were squared off and very hard; they've been very good on caliper pins in particular. |
The rounded crown on some hex head bits have caused the unnecessary rounding out of a lot of heads for folks....really irritating. I've done the same thing...ground the stupid things flat.
************************************************** *** " Time you enjoy wasting, is not wasted." - John Lennon ![]() “I predict future happiness for Americans, if they can prevent the government from wasting the labors of the people under the pretense of taking care of them.” ― Thomas Jefferson "If you don't know where you're going any road will take you there" ....George Harrison song |
#9 | |
It would go a long way in solving many maintenance issues if CSC could specify a better quality of bolts, nuts, and screws. I have replaced all the body panel bolts and screws with stainless steel ones, and a dozen or more bolts on other parts of the RX3. In 50+ years of doing my own maintenance and repairs on motorcycles, cars, outboard engines, tractors, and lawn equipment, I have never stripped so many bolts on any one vehicle. jb
Thanks for the cross reference. Much appreciated
I just replaced the valve cover bolts on mine today with stainless steel ones, washers and lock washers using anti-sieze. The stock ones has started to round and I had to use an SAE socket on one of them as the metric WAS spinning. It's an old trick my father taught me that works sometimes as you get lucky with the SAE being just a bit tighter in some sizes than a metric equivalent.
2017 BMW F800GS Adventure |
#12 | |
Live Zong, and Prosper |
I wanted to get confirmation that others have been successful getting them off with a heat gun instead of a torch? If so, how much time did you let it heat on a single bolt?
Here is a pretty cool video doing a comparison of different methods to remove Loctite bolts. The heat gun took 4 mins vs 1 min with a torch. However, the small exposed bolt is definitely a best-case scenario as it gets direct heat, compared to our hub mounts. I'm debating to buy a butane torch. I'm also having no luck removing my swingarm bearings with the heat gun and hammering down on a 19mm socket. |
#14 |
RC, I use a hand held butane torch. It's easy to control exactly where the heat is going. My heat gun blows out a larger blast of hot air, heating up much more area than I want....and not getting nearly as hot where I really want the heat. With the torch I found it super easy to remove those bolts. I also replaced the OEM rotor bolts with aftermarket ones which seem to be made of much harder metal.
Peter Y. |
#15 | |
And yes I have the KLR rotor bolts already. |
