Old 05-17-2017, 02:05 PM   #1
mikecombs66   mikecombs66 is offline
Cinese atv Zongshen 250cc fresh rebuild white smoking at idle and acceleration, help.
New fresh top end, new head,cylinder,piston,rings,head gasket, new ignition,fresh gas,fresh oil, starts and idles but white smoke puffing away at idle and reving the engine, I checked the spark plug, its black, cleaned it up and no help. Is it the new carb I put on with a bad mixture? could it be oil ? I have excellent compression. I was there when the mechanic double checked the rings and the clearance. What should I do? Its a Peace ATV with the ZONGSHEN 250cc
Old 05-17-2017, 02:24 PM   #2
Water Cooled or Air Cooled?
Old 05-17-2017, 02:33 PM   #3
Mudflap   Mudflap is offline
Plugged crankcase vent?
Old 05-17-2017, 03:55 PM   #4
ben2go   ben2go is offline
If the plug is black, there is a rich condition. If the plug is black and greasy, it's blowing oil by a valve or the rings. Did you stagger the ring gaps 45 degrees from one another when you installed the piston?
Old 05-17-2017, 04:58 PM   #5
Adjuster's Avatar
May just need to be ran hard to seat everything.
My first thought was also the ring gaps.
Old 05-17-2017, 07:33 PM   #6
white smoke
I had one like that before... never did find out from the customer what it was,... it was an air cooled motor o a Z STAR kids quad... ran good,... if it is a plugged breather then seals leak after too much built up... do not know .. interesting
ABIBABA ATV ETC
Old 05-17-2017, 10:36 PM   #7
Darth Racer's Avatar
I'm with Ben2go on this.
Old 05-19-2017, 12:28 AM   #8
i believe white smoke is oil and black smoke is too rich but i could have it backwards
2016 hawk
kaw h1 400 tripple
13' long chopper in progress
2009 johnny pag bar hog
Old 05-19-2017, 12:32 AM   #9
white smoke
I do not think you will find out... white smoke is usualy moisture... cold air... but not in this aor cooled motor.... running to cool... and water is in a water cooled motor... strange one..
ABIBABA ATV ETC
Old 05-19-2017, 09:10 AM   #10
We don't know if its Water Cooled or Air Cooled? If water cooled it could be a leaking gasket letting water into the system. Also could just be oil in the exhaust that hasn't burnt off yet. I did a rebuild on my Honda 200x and it smoked when I started it but would clear up after a few minutes. Turned out to be a defective exhaust valve seal. Had no signs of oil on plug and did burn oil. It crazy how much smoke a few drops can make when in the exhaust. Drove me crazy trying to figure out why it smoked.
Old 05-19-2017, 09:38 PM   #11
If it's white with a blue hue, it's oil and hard to see. If it's steamy white, and maybe a little gray, it's condensate. A coolant leak is usually thick and white like a cloud. It can also have a sweet smell depending on the coolant type used.
Old 05-23-2017, 10:04 PM   #12
poster reply
poster just posted the help post and then left us hanging... I guess he does not need any help .. as all posting should be with all the info needed. would help do you not think????
ABIBABA ATV ETC
smoking, white smoke, zongshen
