My Bashan BSR250 arrived!
After a long, tedious wait, it finally arrived last night. I started assembly right away, but had to leave it unfinished. I want to take my time, do it right and loctite everything I think needs it. I'm still working on it today, and I have some questions.
First question - allen bolts to mount the ignition switch? Those were the only bolts that fit that there were two of. I wasn't sure, but used them anyway. Second - I have two wires with nothing to plug into them - a green double plug (the front turn signals plug into another just like it and all 4 work), and a brown single plug. What plugs into these wires? Anything specific I should look out for? Pics to follow. BTW - I refuse to call it an "Enforcer". Thanks, Matt Last edited by MacGregor; 01-17-2018 at 06:34 PM. |
Learn to say it in chinese. Maybe, punisher? Manipulater?
Cool you got your bike.
2006 roketa 200cc 1971 Yamaha xs650 2x 1980 xs650, 1 is a café, other is a chopper/brat 1972 Honda xl250 2x early 90's Honda rf600 parts bikes more mc junk laying around. ![]() |
I think 'Enforcer' was a name Don came up with. The 'fake' MCO and the bike itself are listed as BSR250. Enforcer is not listed anywhere except on the website.
Oh...I have pretty much everything account for, except for a few spare washers and two nuts and bolt with hex heads. I can't think of what they're for unless they're for mounting the license plate?
for the rear shock just lay the bike on its side.
brown wire is + and green is- so its probably for future additions that req power
#7 | |
Looking forward to some pictures of the finished product. ![]()
Here she is, mostly done. Still need to put on mirrors and some accessories and adjust a few things. The rear tire was flat when I took it off the stand; I do have replacement HD tubes, but won't get to those tonight. I started it and rode it briefly around the block. Will be changing the oil after supper. I think I'm going to like it.
Nice! I'm waiting for my Enforcer to arrive errr...BSR.
![]() Good luck with the build - thanks for posting pointers! |
Everything seems to be working fine despite those wires not being connected to anything. It took me a while to figure out that the headlight and taillight simultaneously turn on and off with a switch (I initially thought the lights were off because of the wires, or that they only illuminate when the engine is running).
The washers with the nubs on them go under the instrument cluster; it looks like there are extras. The two long(er) bolts attach the ignition housing (the plate on top), the two allen bolts attach the ignition switch itself. You'll have to attach the ignition plate first, then the ignition switch. The four short(er) bolts attach the front fender. The plastic panels that attach to the gas tank can be a PITA, at least the right side was - one of the tabs broke. There is a rod that runs along the front of the engine these attach to - it may not line up exact so you might have to finagle it some. I found it is pretty easy to work on when it's on a dirt bike stand. Get the bike off the crate, temporarily mount the front wheel, then put it on a stand. It will make attaching the rear shock much easier than trying to have one person lift the rear while the other tries to get the bolt through. Don't forget to grease the bolt first. The spring for the kickstand is a bit tricky. I used a screwdriver, which worked well. At first it may not feel like it will work; just pull a little harder and it becomes quite easy and slides right on. Other than the side panel on the gas tank, no issues so far. I'm almost done, and should have it done tomorrow. |
Nice looking bike! Thanks for the pics.
As a tip for the next China Rider to install a kickstand spring, insert several washers or coins between the coils of the spring. That will expand it to a length that makes it easy to install without producing any blood.
#12 | |
Great Progress! Can't wait to see some pitchers! What color is the thing? I'm trying to find the original "Enforcer" Thread of (I think) the first to guys to purchase and document them here.
My Stable- 2022 Lifan KPX250 , 2023 Royal Enfield Himalayan, 1992 Honda GL1500 Goldwing, SSR 70 Auto, Kymco Mongoose 90, Honda Four Trax 300 |
#14 | |
#15 |
Bike looks great.
250, bashan, chinese, enduro, enforcer |
