02-12-2018, 12:17 PM | #1 |
2006 Roketa RMS 200ccE DB
Hey all... I bought my Roketa back in October or November of 2017 to have a little fun on my 20 acres of land here and it was a little rough at first... while riding... the battery fell out on the ground... I fixed that... took it out again and the muffler fell off... fix that and took it out again... then the clutch would not engage... the exhaust pipe was laying on the clutch lever... so I fixed that and took it out again... then the ignition switch came out the holder... so I found that there was only one screw holding it in so went to Lowes and bought a screw and I fixed that too... I was wondering why my gear shift lever was so hard to shift through the gears.. I found out the previous owner over filled it with oil... he dumped at least 2 quarts of oil in the... so I changed the oil and put a quart in there.. now it shifted good... then I found out my foot brake was turned too far in towards the motor... so I pried the brake lever out several times until it matched my foot... then I found my seat screw was stripped... so I ran a thread chaser in the nut and bought 2 new screws to secure the seat... then I found my plug wire laying against the head and started burning through the wire.. so I bought some wire looms and fixed that... my bike was leaking oil bad through the crankcase vent hose.. so I fixed that too... Then I found that the fuel cut off valve was locked up.. so I sprayed lube on it and freed that up...
I am still finding some things wrong with it... but this is not the makers fault... the previous owner was just too lazy to fix it the right way... Now the like runs as it should... I still need to look at the gas tank because there is a little rust in there... but now she is a nice riding bike...
2006 Roketa DB-07-200 Dual Sport 2007 Monte Carlo SS 5.3 2010 Challenger Hemi 5.7 2004 Isuzu Rodeo 1998 Kia Sportage 4x4 2004 Toyota Tundra 2016 Ford Escape Guitars 1970 Gibson SG mint Condition 2005 Epiphone white Custom SG Les Paul L/New Fender Banjo New Condition BC Rich Bitch - Like New\ 3 Jay Turser SG Good Condition Amps Marshall vs100 Good Condition Acoustic 261 very good condition Boss GT-6 Pedal effects Like New |
02-12-2018, 02:54 PM | #2 |
I think one post would do three posts in the same forum is a little to many. Glad you joined us. We like pics.
02-12-2018, 03:46 PM | #3 |
yea.. I was editing my post and it posted 3 times... I was trying to delte 2 of them but I could find how to delete them... sorry...
