Got my oil cooler, couple questions.
A couple or several questions actually.
First off I have read over and over all the threads on Hawk oil coolers I can find. 1. I assume just by my cursory inspection the screen stays out from the oil drain hole and the adapter thingy just screws in? How much torque? My normal technique of torque it until it crack then back it off a quarter is probably counter productive. 2. Do I need to prime anything like use a funnel and pour oil into the cooler once the bottom park it attached in the motor before startup? 3. 2 quarts of oil will be more than sufficient to fill er up? 4. Do you like gladiator movies? Wait......... ![]() 5. Any other tips to make it go easier? |
#2 | |
2. It's always a good idea to prime the oil cooler. You can try to use a syringe or small funnel, but usually I will crank the bike over with the ignition disabled (and fuel turned off) until I get oil out of the return line. Either way will suffice. 3. 2 quarts is more than enough, unless you opted for one massive oil cooler lol. 4. Have you ever been in a Turkish prison? 5. Patience.
Megadan has it covered
Thanks fellas will get that installed on sunday
