Old 06-24-2018, 05:24 PM   #1
tzalmaves   tzalmaves is offline
Question Bashan Storm bogs with more throttle - fuel octane?
Hello,
My Bashan Storm bogs down when I apply more throttle. I'm using old-ish, regular octane fuel from my shed.
Do I just need new fuel, or does the storm run better with a higher octane fuel, or is it something else?
Old 06-24-2018, 08:39 PM   #2
dossbag   dossbag is offline
dossbag's Avatar
Did you leave it over the winter with gas in it?
Did you make any changes?
Don't use old gas.. flush it out, put in new and add a bit of sea foam/ You can't trouble shoot with old gas in. I always run mine on low grade and it's been fine
2014 Bashan Storm 250 Enduro
1998 Harley Davidson Fat Boy
1993 Suzuki GSX600F - Rebuilt
1995 Harley Davidson Chopper build from ground up.
1983 Yamaha XJ900 REBUILT!
1971 Triumph Daytona 500 - Restored
1987 Yamaha FJ1200
Old 06-24-2018, 09:58 PM   #3
Brand new unit, first ride.
Old 06-24-2018, 09:37 PM   #4
Hawk 229cc   Hawk 229cc is offline
Hawk 229cc's Avatar
sounds like the air issue could be ,old gas wont help i am useing 89 ,but fresh 87 should be fine,stock carb ? ,if so look to the upgraded carb also i am finding out it takes 100 to 200 miles to break them in an get the full power of the 229cc more like 500, along with the right carb tuning an air to it,right now mine wont go over 40mph ,but i am at 75 miles an geting ready to do the carb & jeting as wel as the crf 230l aftermarket exhaust ,the carb should bring a few hp also you may want to adjust the valves ,as well ,
so there is a list of the recomened upgrades to them is why i dont have 500 miles on mine yet ,it can take some time to get the bikes right ,in my case going slow to make sure i get most of the important ones ,so in the next few weeks, i will be tearing mine down an doing a ton of crap to it , genuine mikuni carb an jets air box exhaust valves lash adjustment , also like greasing the swing arms bearings wheel bearings an the steering post bearings an fork oil ,as well as the chain an sprockets for last ,then some dual sport tires for the road,then i am still not done but getting there
Also going to trim my seat to make it as flat as possible ,lowering the rear break pedal as well ,softer hand grips for vibration,helps remind me ,edit to my list of things to do
Old 06-24-2018, 09:58 PM   #5
Yes, It's brand new, today was my first ride.
Old 06-24-2018, 09:55 PM   #6
Ariel Red Hunter's Avatar
Originally Posted by tzalmaves View Post
Hello,
I recommend non-Ethanol Premium because of less issues if the bike is not used at least weekly. I would definatley get rid of the old fuel and use fresh, especially if it was regular...ARH
Old 06-24-2018, 10:04 PM   #7
Hawk 229cc's Avatar
yup look at the my post again ,go to youtube an look at hawk videos will be simular as well as bashan storm videos ,hope you took that oil from china out an put some motortcycle oil in it too,if not first thing is change the oil 10w40 should work some use the 15 w 40 ,wich i may change to later on for the zinc in it
take your time ride it bit but plan all the important upgrades ,carbs like $36.00 jet kit 10.00 pilots 5.00 each,but yes take your time an research an more research to get it running like a top
Old 06-24-2018, 10:28 PM   #8
Hello,
sounds like choke is on to me
2016 hawk
kaw h1 400 tripple
13' long chopper in progress
2009 johnny pag bar hog
Old 06-24-2018, 10:49 PM   #9
Buffalorider   Buffalorider is offline
Just like Timcosby said im almost certain this is a choke issue, it has happened to me when I wasnt paying attention, then I was like duhhhh my choke was the wrong direction. I moved it and Bang! my bike was just fine.
Old 06-24-2018, 11:06 PM   #10
Hawk 229cc's Avatar
up choke on down off for hawk ? if that is it on a hawk can only guess same carb,couse i know its the same engine .?what prevents the bashan storm 250 from needing the upgrades the hawks needs to run right in most cases ??, missing something hear , the direction of the choke an how it works on bashan storm ??? well guess they know that too
Old 06-25-2018, 08:24 AM   #11
The choke lever is in the 50% position, so that is no doubt the issue. Until now, I couldn't find the choke, so I assumed this model didn't have one. Thanks all!
Old 06-25-2018, 10:17 AM   #12
Happy we could help!!
