01-21-2019, 11:02 AM | #1 |
ZS190 Swappers!
Anybody want to sell me their old motor? I've tried replacing the jug on mine, but after having problems with things fitting, I just want a new motor. I live in Maine, would be willing to pay plus packing and shipping fees.
01-24-2019, 07:26 PM | #2 |
I will be doing the swap but won't happen for several months. U can get new engines for a little over 200.
2018 BD125-8-x21rs ZS190/Genuine PE28 Kepspeed GP1 Exhaust Protaper se x110 bars/grips 1/4 MotionPro throttle Kepspeed Braced swingarm Chimera rear hub assy Grom Intergrated tail light Superlite Sprockets 17/32 custom made from Japan Chimera Swing Arm Bolt RK MXZ Chain #420 All Balls wheel bearings Motodynamic fender eliminator Coremoto ss brake lines Composimo 2.5 lower link Grom Calipers-w/ebc pads/rotors Michelin tire 140&120 13x4/13x7 fatties Grom forks |
01-25-2019, 08:11 AM | #3 |
Really? I've only seen them priced around $350 not including shipping. I've considered doing the zs190 swap myself, but I'm about to take on a mortgage I'll keep you in the back of my mind come springtime when I pull all of my broken bikes out!
04-03-2019, 12:10 AM | #4 |
I have a 125cc motor off my 2017 SSR Razkull I'm looking to part ways with now... has about 2,000 miles on it. Broken in properly, oil changed every 300-400 miles with Mobil 1 Racing 4T 10W-40 motorcycle oil. Oil filter screen pulled and cleaned every other oil change. Will throw in an extra brand new clutch cover gasket from tbolt usa.
It's a three bolt pattern design just as a Honda grom has, may want to double check but you will probably need engine brackets to use this in a clone (Boom, Venom, Vader, etc.) Shift pattern is 1 down, 3 up. 16T sprocket on it. PM me if you're interested! |
04-03-2019, 12:28 AM | #5 | |
04-03-2019, 07:50 AM | #6 | |
04-03-2019, 07:52 AM | #7 |
Nice.
04-03-2019, 05:27 PM | #8 |
Where did you find the 190 for $640?!?!
04-04-2019, 03:13 AM | #9 |
@loganlex - I told ya about pulling trigger on that coupon on your "Looking for thoughts and ideas" post yesterday haha. Not sure how much longer Gary at Pitsterpro is going to be running that dirtcheap bargain...
if that coupon code stops working you can always use "miked" at check out...comes out to $743 w/ shipping |
04-05-2019, 09:47 AM | #10 |
Always keep your eyes on the webdeals threads!
04-04-2019, 04:59 AM | #12 |
Would highly suggest changing the swingarm with something stronger if swapping to the 190. I put a Grom swingarm on mine and replaced the rubber bushings with the brass ones from mnnthbx.com
04-05-2019, 11:31 AM | #13 |
I know you've kinda just gotten started on your swap, but have you had to tune the carb that came with it at all, or just running it stock?
04-09-2019, 01:30 PM | #14 |
I ordered one yesterday. I'm looking forward to having real chain adjusters lol. Any real need to change the bushings if they are in decent shape? Mine is coming with bushings, chain adjusters, and chain guard for $119.
