How do I - Mikuni VM22 tuning during break in
I am not sure the best way to tune this thing. It is a knock off made in Japan or so the label says.
I guess I should adjust it a bit rich. I really suck at tuning carburetors even CVK ones with one screw for fuel mix let alone this one with both a fuel and air screw. Any advice would be appreciated. |
#2 | |
Hawk 250 ![]() Lithium Battery, Mikuni Carb 110 main jet, Bark Busters with Mirrors, Extended Mixture Screw, 428 O-ring Chain, 17-15/40 sprockets, Digital Cluster, Cycra YZ250F Skid Plate, Oil Cooler |
Thanks.
So my buddy and I went to install the same carb and he’s telling me I’m gonna lose my choke option and other things. Did you notice any compatibility issues or is he trippin? I’ve ready plenty of reviews and not a single issue he brought up anyone else has mentioned.
#5 | ||
From my reply in the other thread. Quote:
Okay, so i went riding today after adjusting the idle. So far the engine seems okay. The carb needs some more adjustments though.
The problem It bogs when trying to go 1/2 to WOT. According to this it has to do with the needle and slide. I have no idea how to adjust the slide and I don't remember seeing any notches on the needle to adjust the needle height. I am at sea level and it is 35F out. Do you think going down a size from the 110 main would help? Last edited by scoot newb; 03-18-2019 at 04:18 PM. |
You need to do a plug chop.
http://www.mikuni.com/pdf/vmmanual.pdf This is the manual for mikuni VM series. Search google and youtube for instructions on doing a plug chop. Only way to tell if you're lean or rich and which jets are responsible. Only other way would be to put in an O2 bung and get a wideband to see if you're rich or lean. Increase jet size if lean. Decrease if rich. Altitude will play a role in what jet size to use. |
I couldn't do a plug chop. With the 110, 115, and 120 main jets I tried, there was not way to go WOT. After half throttle it got flaky. For the heck of it, I went down to 105 and it is almost perfect, just after 7/8 throttle it cuts out/bogs. I am going to try 100 and see what happens. I think the air filter I'm running is super restrictive.
100 is working fine. I can use all of the throttle. Last edited by scoot newb; 03-20-2019 at 03:21 AM. |
