06-01-2019, 07:46 PM | #1 |
Orion rxb 250cc
Received the bike late last night, no damage to report from shipping. Only thing missing is the two springs that hold the muffler on.
Started this morning assembling, normal stuff like loctite bolts, and make sure everything is tight. Suprised that most all bolts were very tight. Only have one stripped thread on the upper mount for the rear subframe. I lubed front and rear wheel bearings, cleaned both rotors, and will finish tomorrow greasing the shock linkage, swingarm bolt and such. I pulled all the stickers off, did notice the bike has had a lot of greasy hands on the plastics that haven't been cleaned off. Easy to wipe off, but still it's a new bike you'd figure it would be clean. Drained shipping oil, added 1.5L of 15W40 Rotella, and adjusted valves on a cold engine, 0.004" intake and 0.005" exhaust. Pulled the carburetor (NIBBI brand), pilot is less than 0.018" (smallest bit I have to check), but not by much, and I left as is. The pilot is marked #40 and the main is marked #120. The stock main jet measured @ 0.045" to 0.048" with the clip on the second notch from the bottom. I drilled it to 0.052", and put the clip in the middle. Stock, the air mixture screw was 4 full turns out from bottom. Ran the engine till warm and set the air mixture screw to 1 1/2 turns from bottom, which was the best idle. I'm just above sea level, it was 90 degrees and high humidity. So far it starts on a dime, runs smooth and that muffler is LOUD (it does sound good, though). Should get some easy ride time in tomorrow to start breaking in the engine. I'll keep ya updated... Kirk |
06-01-2019, 07:50 PM | #2 |
Oh, one thing I forgot...you have to pull the intake manifold to get the carburetor out. When I did the gasket was turned the wrong way and partially blocking the entrance to the cylinder head. Flipped it around and fits like it should.
Kirk |
06-01-2019, 07:50 PM | #3 |
Congrats on the new bike. enjoy the ride.
06-01-2019, 07:51 PM | #4 |
Yes sir, and thank you.
Kirk |
06-01-2019, 10:39 PM | #5 |
where are the pictures...
06-02-2019, 07:57 PM | #7 |
Here is a pic of it finally assembled, lubed, and loctited. Got about 20 minutes of limited/easy riding today. It's Sunday, and with this loud bike I thought I would be kind to the neighbors. I have a little hesitation about 1/4 throttle, and plan to move the needle clip down a notch to see if it clears up. Still need to do a plug chop, but plan on it after break-in. Then we can really dial this engine in. Clutch is very easy pull, brakes are pretty good, engine pulls great and runs smooth, and suspension is about right on target with my 225lbs self. Playing with the clickers today, about 5 or so clicks out from full soft on compression on the forks and mid way on shock. Will be working on some kind of spark arrestor/Db killer this week when I take apart the muffler. Also, another missing part I found was the bracket to screw the number plate to. Other than that, it's gonna be a great bike. I'll let y'all know what's up next soon.
Kirk |
06-03-2019, 01:07 AM | #8 |
If someone would start importing this type/style of China
bike here I would be temped to get another.. just don't want to brake the frame and twist the swing arm like my last one.... the motor held togeather... I did get 7 months out of it... I keep looking but no one here imports China bikes anymore... no one will buy them... they f#@&% the market for themselves by bringing in cheap crap to make a quick dollar... ..
06-03-2019, 12:37 PM | #9 |
Searching around for some type of Db killer, I found on Cozzoo (never heard of) and AliExpress, an insert that is the same shape as our muffler ends (kind of vagina shaped if you ask me). They are just perforated tube, no spark arrestor screen, but worth a try at $11 or so.
Also you could insert a 51mm perforated tube baffle on the intake side of muffler for even cheaper. They have those types with and without the catalytic substrate in them. The catalysis could act as a spark arrestor, but it chokes the exhaust by a considerable amount. For a spark arrestor on the other you could wrap some fine mesh SS screen around the outside of the baffle and secure it by welding or small pipe clamp. Anyone else find or know of a low dollar fix? Kirk |
06-03-2019, 12:48 PM | #10 |
Wanted to show a pic of the catalysis which is in some of the baffles I was talking about earlier...
This is just a pic showing what some of the baffle tubes have inside them, not the baffle I plan to purchase. That doesn't look too restrictive to me. If it is, I can simply start by drilling holes until I get what is needed. What's your thoughts? Kirk |
06-06-2019, 11:11 AM | #12 |
Took the muffler apart yesterday, very good muffler packing I must say. The end cap consists of two parts welded together, the shiny end cover and actual end piece. It only has a couple of small spot welds holding it together. The end cap has a small length of pipe that inserts into the 38mm perforated tube. I will say, they missed on a few drilled holes for the rivets when installing the end cap...3 of the six holes are drilled right at the edge with little to hold to.
The intake side of the muffler is 51mm, but for only about 2" then funnels down to the 38mm perforated tube. Saying this because my Db killer might be too long to insert. I may have to cut off the part of the Db killer to make it work. Was looking for a way to install spark arrestor screen of some type, also. I have a couple of ideas, one involves brazing some funnel shaped SS mesh screen to the Db killer after it is cut to length. The other is buy the quiet core insert for the LEXX muffler that RockymountainATVMC offers and incorporate it into the end cap. I've done the latter on a pit bike muffler before and it worked well. Kirk ps. for some reason this camera will not take close ups. |
06-11-2019, 06:35 PM | #13 |
Did a little rejetting today, first started with a smaller main, 0.049" that I found in my jetting toolbox (from the original main I drilled to 0.052"). Rode it and something felt missing, plus it was popping on decal. Came back readjusted air screw from 2 to 1 5/8 turns out, rode it, no decal popping and almost there...unscrewed top of carb, pulled needle and set it to 4th notch from top instead of the middle and I think I found my sweet spot. Engine sounds good, pulls great getting into the throttle, and I am a happy camper. Today was a little cooler for Texas, @ 80 degrees instead of the upper 90's like it usually is. I'm going to leave this setting alone for a while, well until I do my first plug chop. Then we'll see how close I am once I read that plug.
The bike sound great with the quiet core, almost stealth-like. Sounds just like a stock XR250 I had once, that's the way I like it, too. A few more things I would like to do is add a headlight/tail light and hand guards. Got some cheapo bark buster guards on order already, and the lights won't be too far behind. I'll keep y'all updated as usual... Kirk ps. I know the quiet core tip looks a little out of place, but I never look back there when riding anyway. |
06-12-2019, 11:00 AM | #14 |
Excellent info. I'm also preparing to order an insert from RMATVMC, but I may even go to the next step down in volume. I'll reply back with which direction I ultimately go, as well as what happens with jetting and performance post-install.
06-13-2019, 04:19 PM | #15 |
DJ, the two quite cores are just about the same besides a few less holes drilled in the "trail-friendly" version, the tip is turned-down more, and a sound deflection ring of some sort. This might get you to even be able to run "super-stealth". I know my exhaust note now is very, very pleasing to the ears from what it was. Heck, with that installed you might not even need to re-jet, either. Keep us updated...
Kirk |
