Hi guys, I need some help please. I bought new neutral and Reverse gear indicator lights. But cannot see or figure out where to wire them into? My gear selector switch that goes into the gear box only has 2 wires....... any help is appropriated.
The way this works is battery + is connected to the bulbs. The negative wires from the bulbs go to the switch on the transmission. When in neutral the switch grounds the wire from the neutral indicator bulb, completing the circuit. Same with reverse.
just got to look at the right place..... like here
My taotao 110cc atv will not run more than 1 second after it starts. What's up with it
It’s broken .
#7 | |
But, you need to give us A LOT more information than that. It could be a carburetor problem, something on the CDI ignition, a large leak in the intake after the carb, valves out of alignment, engine compression too low... With what you've given us, all we can say it was Bruce already did. It's broken. |
