09-28-2019, 12:18 AM | #1 |
Just purchased 2 raptor 200's need general info
These will be my 2 first ATV's, I know people suggest changing the oil before first start, but I was wondering about general things. Like what to do/not to do. What nuts/bolt to check and tighten... Any other odds and ends things I can't think of
09-28-2019, 01:55 AM | #2 |
It's powered by a steroided GY6. Machinist told u already https://www.motorfans.com.cn/forum.p...=290040&page=1 (Google chrome can auto translate the text. Use Google translate Apps if want to know what's the text inside image) what's inside GY6 design. Oil, oil & oil... is the key-point.
09-28-2019, 02:14 AM | #3 | |
This is an odd response.. Was it directed at me? |
09-28-2019, 09:39 AM | #4 |
Human being lives in Hong Kong meaning English is not his first language. He is VERY helpful, but it usually takes a few posts from him to understand exactly what he is posting. On the deeply technical stuff he posts, such as wiring diagrams, he loses me. But he has MUCH knowledge to share.
What he is getting at as far as your new quads--the engines are essentially the common GY6 scooter engines, so whatever information you can find for the GY6 will apply for your engines.
09-28-2019, 10:04 AM | #5 |
what @Culcune said....@HumanBeing lives in HK, and i believe the link he posted was about some of the things that can go wrong with not changing the oil regularly? i just skimmed the thread a bit, and the translation from the native language leaves a lot to be desired on that site....LOL
as for bolts to check, if it is a bolt or nut, CHECK IT.......LOL pull it and put some blue loctite or similar threadlocking substance on the threads. also, before starting the motor, most Chinariders recommend checking the valve clearances, as they are commonly too tight from the factory, and will cause poor starting/running/owner frustration LOL |
09-28-2019, 11:36 AM | #6 |
Please note also that there is gear oil at the rear of the CVT; you'll find a fill plug and a drain plug. I use synthetic 75W90.
09-28-2019, 12:03 PM | #7 |
When the ATVs arrive, plan on spending a few hours going through it. Before you start to put the remaing parts together, put a wrench on everything that you can touch. Bolts that are subject to a lot of vibration use blue loctite. Install a new spark plug (NGK), change the engine oil, should be a plug on the bottom , and on the side. THere is a small drain plug in the back of the engine for the grear oil, and the fill plug should be on the rear side of the CVT (left side) cover.
Just go into it with the thought process that you are the quality controll. Check how the wires are roughted, brake lines, ect. I have the 2018 Bull 200 with about 30 hard hours on it. I have had a few of the body bolts fall out, and I need to occasionally check the rear axle nuts at the carrier, and the rear hub nuts. Asside from this the ATV has been very good. Oh yeah, I have been using the Rotella 15w40 oil since new, and I have driven it like it was stolen every time i have taken it out. So far So good... Douglass |
09-28-2019, 01:38 PM | #8 | |
Someone else said use loctite on all nuts, Would that be a problem? |
09-30-2019, 11:01 AM | #9 |
Nope, not at all. This is just what I have done with my bikes. I started with as many bolts as I could touch, to the bolts I felt were subject to the most vibration. |
09-30-2019, 11:07 AM | #10 |
i am the one that said all bolts and nuts.... my opnion, if its a bolt on a china bike, its prone to vibration...LOL
11-01-2019, 10:34 PM | #11 |
So they finally came, but it seems like you have to push the throttle more than you should to get them going, then they almost jump, is this normal?
11-04-2019, 08:58 AM | #12 | |
You need to rev up the engine a bit and it'll go nowhere at first, but there is a specified rpm at which the clutch will engage and then the quad moves. After that, you can operate within the rev range of the engine and you'll be fine.. but if you let it return to idle, the clutch will disengage and you'll be essentially "in neutral". Most GY6 clutches are set up (with internal springs) to about 1500 rpm. So below that engine speed, it just free revs. By comparison, my sons' Tao New Cheetah with F-N-R geared transmission is instant go when applying throttle. It's just different. |
11-04-2019, 04:36 PM | #13 | |
First of all, sweet Daiblo name. Secondly, thanks for the reply! It's good to know, it was weird at first, but a few hours and I got used to it, I do wish it turned a little easier.. Seems to not want to turn all that well.. Also, it came about 99% assembled. Didn't have to put on the steering arm or anything, and after about 5 hours of riding, all the bolts still seem tight from the factory. I check all I could see.. All these suggested things don't seem to be an issue for the two I got. If someone can however, help me navigate where the gear oil is, and how to change it I would be very appreciative of that! |
11-05-2019, 07:58 AM | #14 | |
Anywho... so the gear oil. Do you see the round-ish section of the engine case where the front sprocket attaches? That is the final drive. On a scooter (where this engine design came from), that's where the rear wheel would attach with a drum brake on the wheel side. My generic quad has a planetary reverse gearbox here. Should be a small bolt on the bottom of that, and a round plastic cap of sorts on top. Fill plug is about 1/3 of the way up on the rearmost side. You'll want one of those oil pump cans with a hose, or a small tube to attach to your gear lube bottle. Fill it until it starts to run out is what I was told. It does not take a lot. |
11-05-2019, 08:12 AM | #15 | |
2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S (Sold) 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 11-06-2019 at 07:48 AM. |
