New Member: Just bought a Flywing MX 100 and a little confused.
So I paid 50 bucks for what I knew was a basket case and planned to rebuild it.... Thinking I may have to swap the motor. It seems to be an electric start. on a bike that doesn't have a place to mount a battery...
I read some where on this forum (by the way THANK YOU to all who have been sharing info!!!) that a 125 will mount right up to this bike. So I was thinking about buying: Engine Assembly - 125cc 4-Speed Kick Start for Dirt Bike - Version 15 Will this work? I should say that thought I have ridden street bikes my whole life I have never ridden dirt. ![]()
T Bear early to mid 1970's Kawasaki F11 250 2003 Harley Wide Glide 2004 Jianshe Flywing MX 100 2007 Yamaha VStar Proof of motorcycles in biblical times: "David's Triumph was heard throughout the land." ![]() Last edited by T Bear; 12-02-2019 at 05:54 PM. Reason: Broken link |
Welcome! That's a bike I have some experience with. It's loosely based on the Yamaha PW80, with engine mounts for a horizontal Honda clone; the 125 is likely a bolt-in deal. When it's dialed it, it'll go like a scared rabbit.
That exhaust is awful and needs to go. It's also based on the PW80, which is a two-stroke. You can see how there is an expansion chamber that is not helpful and the pipe necks down after the chamber, just before the muffler. A generic pit bike pipe and muffler will do the trick (they're cheap and plentiful). You might have trouble getting a pod filter to fit, since there is little room between the carb inlet and the frame. I solved that with a 45 degree intake and a foam pod on my son's first bike. You can also get a cheap carb rotator if necessary, to tilt the carb as necessary.
Thanx Weldangrind. I have read a lot of your post and gained a lot from them. I have some VERY noob questions.
I have tried like hell to find a manual in English with no luck. I've also seen many on this forum doing the same SO... I am kind of piece together information where I can. Wiring - should I be using a PW80 wiring diagram/harness or something from Honda? or does it really matter since I'm starting from scratch? If I'm correct all I need is a CDI, Coil, Kill switch, and the stator (which I think comes with the motor) since its a kick start only. Fuel - in a street bike I run 93 octane. Should I be running the same in a dirt bike? 45 degree intake - any chance you can show me what you did exactly and where I can get it?
T Bear early to mid 1970's Kawasaki F11 250 2003 Harley Wide Glide 2004 Jianshe Flywing MX 100 2007 Yamaha VStar Proof of motorcycles in biblical times: "David's Triumph was heard throughout the land." ![]() |
#4 | |
Despite that engine being a good deal, perhaps you'd care to shop for one that includes a complete wiring harness. It'd be nice to know that it's a matched system. I use regular fuel, unless it's a high compression engine. High octane will only make a low compression engine harder to start. Here's what I had in mind for the intake: https://www.ebay.com/itm/Black-26mm-...YAAOSw-0xYbofx Here's a cool option: https://www.ebay.com/itm/Manifold-In...oAAOSwYmZXG0WR
Just curious, did you ever put the 125cc. Motor in? Thanks!
My suggestion would be to buy the 125 you've linked above, and then go to TBoltUSA.com and get a complete electrical system from the Flywheel/stator to the kill switch for $99.00. The kit is complete so you know everything is compatible, you'll need a flywheel puller tool to swap the flywheel and stator on the 125 you buy.
You can also pick up a reasonably priced exhaust system that will work on your bike, and yes, you can run 93 octane in the bike. full electrical system flywheel puller exhaust system |
