12-17-2019, 03:22 PM | #1 |
New bike coming / It's here
Just ordered a MotoMax 250 and am wondering about the carb. This bike is to have the same engine as the Brozz 250, so what brand of carb do these have. I am wanting to know because the reviews I have seen says they need to be re-jetted. Will Mikuni jets work in these?? Thanks
12-17-2019, 04:07 PM | #2 |
It should take Keihin jets. I would wait till you get the bike to make sure on what type of jet it has in it.
12-17-2019, 08:09 PM | #4 |
I recently got a Brozz 250 from Peace....like you, I had my tracking # by 6:00 the evening I ordered,...and delivery was less than 48 hours later (VA)...complete with all necessary paperwork.
<div>Steve 2006 Roketa DB-07A/RSX-200E 2008 Roketa 250 Scooter 2019 Brozz 250 |
12-17-2019, 08:25 PM | #5 |
You are way closer than me. I am hoping to get it by the end of next week. I know Saia is pretty efficient. I once ordered a zero turn mower from a dealer up in IL., it was shipped thru Saia, and I had it at my door in about 4 or 5 days.
12-18-2019, 05:07 PM | #6 | |
12-18-2019, 06:34 PM | #7 | |
For the average person/consumer,..it cannot be improved on as delivered. I'm at 1000' elevation. I did adjust the valves during set-up. Without the valve adjustment, I'm sure it would have shown some start-up and running issues, as they were very tight. Stock carb is the made-in-japan Keihin.
<div>Steve 2006 Roketa DB-07A/RSX-200E 2008 Roketa 250 Scooter 2019 Brozz 250 Last edited by cycleway4; 12-18-2019 at 07:41 PM. |
12-18-2019, 07:01 PM | #8 | |
12-24-2019, 11:47 AM | #9 |
Got the bike yesterday. The shipping carton looked pretty beat up, but the bike had no blemishes whatsoever. I was missing one of the sleeves for the pegs, contacted Jeff and he is sending me one out today. Got it all together and started it up. I let it run for a while on the choke and when I switched the choke off, idles perfect. I have been seeing things about heat cycles. What is the best way? When I had it running, I let it get up to about 140* at the head, then shut it down. I am liking it.
12-24-2019, 11:53 AM | #10 |
Just Change out the oil OFTEN and check the valve clearance. The motor will act totally differently after 1000 miles. It’s tight now.
12-24-2019, 12:19 PM | #11 |
It is tight, doesn't make any noises.
12-24-2019, 12:27 PM | #12 |
Red Hawk speaks wisdom.
