12-18-2019, 09:25 AM | #1 |
Zongshen Sierra ZS200GY-2 help!!!
Hello All,
I’ve recently come to own the frame and wheels of an 06 Zongshen Sierra. While she still needs work, I’m having a tough time finding a motor for her in the United States! Can someone help me, please? Any information on the motor, similar useable engines, anything! Thank you! -Tylor |
12-18-2019, 09:50 AM | #2 |
Welcome aboard! You can find 200cc and 250cc engines on ebay.https://www.ebay.com/itm/LIFAN-200CC...AAAOxyOalTYZ1o
One our sponsors Brozz250.com have the counterbalanced cg250's for a real good price and have any engine parts you need for that engine available in the US. Use Coupon Code: "ChinaRider" 5% off any size purchase. Sale good December 06, 2019 to January 03, 2020 https://shop.brozz250.com/eshopprod_...e_Assembly.htm
2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S (Sold) 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 12-18-2019 at 10:33 AM. |
12-18-2019, 10:17 AM | #3 |
JerryHawk250 this will fit the frame of the bike? That’s my concern is that I’ll get the same size motor and it doesn’t fit.
12-18-2019, 10:37 AM | #4 | |
The Brozz counterbalance engine will probably need a custom made front mount to make work. If you have some fabrication skills that would be the one I would go with.
12-18-2019, 11:03 AM | #5 |
If you find that thread do let me know! I wouldn’t mind getting a readily available motor.
12-18-2019, 11:49 AM | #6 |
I did locate the thread but no point in posting it. All the pictures were deleted and no real write up to explain on what was done.
12-19-2019, 06:05 PM | #7 |
the CG or CB are a totally different animal - TW200 family is what you will need to slip right in....
12-18-2019, 12:31 PM | #9 |
Welcome, Tylor! X2 on the XT225 motor. It has more displacement, an OHC, more power and six gears. Total win.
12-18-2019, 01:55 PM | #10 |
Weldangrind, I’ll look into it. I’m all for doing a little fab work if it doesn’t fit!
12-18-2019, 05:05 PM | #11 |
It is a TW200 copy engine 100% ( double check ouitput shaft isn't miles out and the ZS doesn't have a decomp lever
I had this bike me self and sold it recently |
12-18-2019, 10:01 PM | #12 |
Okay, so in the knowledge of everyone present, would you say the Lifan is a worthy resemblance of the motor? I found some possible Zongshen 167FML series motors on this Alibaba website, but I don’t trust it. I’d rather stick to EBay where in the States I know I’ll be okay if it’s a scam. Lifan seems to be the popular eBay ticket. Is it worth it?
12-18-2019, 10:20 PM | #13 |
And also, does anyone have a link to where I can purchase cosmetic parts for the bike? Like the rear light housing, fairings, hamdguards, etc.?
Thank you all so much for your help! |
12-18-2019, 11:12 PM | #14 |
These used literal clones of the Yamaha TW200 engine as others mentioned, if you can find one for a reasonable price. I think Chinese Hondoid (nicknamed that because they are not really identical to any real Honda engines, but are similar) are good alternatives; very reliable! Lifan or Zongshen will do the trick. Personally, I would go with a Lifan engine, but that is personal opinion, and not based on anything--in the end, either one will do the trick.
12-19-2019, 05:58 PM | #15 | |
ONLY Zongshen did this motor no other manufacturer |
zongshen, zongshen 2006, zs167fml |
