Old 04-24-2020, 10:27 AM   #1
Larky   Larky is offline
Disappointment after removing the catalytic converter
Hey guys,
As the title states, I’m not sure I’m happy with the outcome of removing my catalytic converter off my tbr7. I feel as if I’ve lost low end torque. I increased the main jet to a 115. Also ground down the weld at the connection to the head. Looking for suggestions to get it back. I understand the answer might be to get a stock header and leave that cat alone. Let me know what you think.
Old 04-24-2020, 10:33 AM   #2
bogieboy's Avatar
might need a bigger pilot jet... more flow across the board means you may need more fuel across the board as well...
Old 04-24-2020, 10:47 AM   #3
^^^What he said. ^^^ X2 Removing the cat definitely woke up my hawk.
Old 04-24-2020, 11:05 AM   #4
Great! Thanks guys. Is there anything else I should do after the pilot jet? I’m at about 1000-1500 feet above sea level. Just to convey all info, I’ve shimmed the needle jet up one washers thickness. Maybe add a second washer?
Thanks again guys.
Old 04-24-2020, 02:41 PM   #5
Kenstogie   Kenstogie is offline
Kenstogie's Avatar
HUGE difference for me putting on that new exhaust...
what can you do on a tbr7 ( pod?) for the air intake side.......
and how much gain?
been around bikes for a while....
honda 72 cb200t, zuki 96?/2002 katana, 12 vstrom,09 vstar, kawi ltd440, 82 zuki Gs1100, Tao Tbr7
all about the Tao MotorsTBR7
http://www.chinariders.net/showthread.php?t=25553
Old 04-24-2020, 04:10 PM   #6
alex_in_az   alex_in_az is offline
and how much gain?
the intake side is OK on the TBR, once you've done the mods to the carb. I'm just about ready to put a PnP head on my TBR, I had to remove a lot of material from the exhaust port, there's a big lump right by the ex valve that needs to go and on the top side of the port as well. In contrast I hardly did anything to the intake port, because it looked pretty good as is. I decked it .040 as well, so my CR should be around 10.3 if my math is correct
2020 Tao TBR7
9.3:1 PnP head
CRF230F exhaust
4 degree advance key
290 degree cam
Nibbi PE30 and cone filter
Front fork brace
Old 04-24-2020, 04:26 PM   #7
Sounds like my head lol.
Old 04-24-2020, 12:08 PM   #8
Like previously mentioned, the pilot jet.....but if you haven't lifted the needle a notch yet, that may also help.
Old 04-24-2020, 01:24 PM   #9
kingofqueenz   kingofqueenz is offline
No expert...
Isn't the theory "air in ...air out"
Thought I read, the airbox mod on the Hawk does not work on the TBR
Did you mod the air in portion of the equation?
Old 04-24-2020, 01:35 PM   #10
Originally Posted by kingofqueenz View Post
No expert...
Great question! But the answer is no. Didn’t touch the air box. I was under the impression that it wouldn’t add much power. Besides I like the air box / filter combination, especially if there was minimal-to no power gains. Although let me know guys I you felt that an air box mod was worth it.
Old 04-24-2020, 02:07 PM   #11
On its own modding the airbox doesn't result in much because the factory exhausts are restricting the engine enough that the gain is almost imperceptible. When done in support of an exhaust upgrade it can make a difference.
Old 04-24-2020, 01:55 PM   #12
Rocket tests   Rocket tests is offline
Rocket tests's Avatar
Removing the baffle plate from the stock muffler helped mine breath a lot better.
Old 04-24-2020, 08:27 PM   #13
I can say that the port n' polish n' decking is well worth the time it takes. Night and day difference. The biggest drawback on mine is the starter often struggles to overcome the extra compression. I can count on needing to hit the starter button several times before it turn over without stalling the starter. Possibly could be resolved with a stronger battery.
One mod inevitably leads to the next and so on.
Old 04-24-2020, 09:52 PM   #14
Yes, you need a good strong battery if you increase the compression a full point, and if your battery is weak for some reason, you will find out after the first couple of turns.
That said, if you get the idle mixture and pilot jet sizing right, usually it only takes a couple of turns for the bike to start. Usually my bike will fire up right after the second revolution.
IMHO the increased compression, while it definitely adds a bit of oomph to the equation, could also be left out, or at the very least left to a small increase. Opening up the exhaust port and smoothing out the intake as myself, jerry, and obviously a few others have done, makes a big difference in how these engines perform.
Increasing the compression also leads to stronger vibrations, so be aware of that side effect too.
Old 04-24-2020, 10:34 PM   #15
It's amazing, with every mod I make my hair grows fuller and shinier, I can bench press double my previuos weight and my man hood..... well lets just say my wife isn't complaining.
