Old 08-19-2020, 04:02 PM   #1
AceBell   AceBell is offline
Stiff shift lever on Apollo db-36 2019
After a long ride when I come back home and try to switch it into neutral from first the shift lever is very hard to click up. I have a an Apollo DB-36 2019 & I'm a newbie. Also, for some reason after I ride a bit and make a complete stop with the clutch held in the bikes tends to wanna die. What seem to be my problems any advice is welcome. Thanks in advance.
Old 08-19-2020, 04:40 PM   #2
The clutch is dragging once it get hot. You need to adjust the free play in the clutch lever. You want minimal free play, about 1/8" .
Old 08-19-2020, 06:11 PM   #3
So you're saying by adjusting my clutch lever on my handlebar by a minimum of 1/8th of an inch will correct the stiff gear selector & the turn off when i come to a complete stop from riding?
Old 08-19-2020, 06:56 PM   #4
franque   franque is offline
You need more freeplay. Just Google how to adjust a motorcycle cable clutch.
Old 08-19-2020, 08:03 PM   #5
I adjusted the free play just now. Went riding and now at complete stops, after riding for a bit, the bike creeps forward with the clutch lever pulled in all the way.
Old 08-19-2020, 08:18 PM   #6
Bruces   Bruces is offline
Adjust it a little more
Old 08-20-2020, 12:23 PM   #7
I adjusted it more but now feel like its hard to upshift & downshift & cuts off at complete stop. This is very frustrating.
Old 08-20-2020, 12:52 PM   #8
Sounds like you giving it more free play. Even though this is for a TT250. The adjustment procedure is the same. https://www.cscmotorcycles.com/check...and-adjustment
Old 08-25-2020, 07:44 PM   #9
I got it adjusted to my liking but every so often I gotta adjust it on the handle bar lever
Old 08-25-2020, 08:03 PM   #10
Are you a new rider ?
Old 08-26-2020, 06:46 AM   #11
Yes I am.
