11-11-2020, 09:22 PM | #1 |
Chain / sprockets 520 stock
Okay - so apparently I have a different setup on my bike. My chain is a 520, and I have a 13T front, 44T rear. I'm okay as far as ratio, I'm able to get up over 70 downhill, with the wind, on a Tuesday lol anyway I'm wondering about the rear sprocket change. I'd like to lower the RPM range on the upper end of the final so I'm not so screamy at 50.. I would lose a few teeth; right? I did try to get a 17T front and was unsuccessful - and if I did, I don't think it would fit. The front guard already has some hits on it..
The back sprocket does have 4 bolts, but the spacing is a little different than what I was able to find compared to the Hawks rear. From one bolt directly across to the other, I'm getting right at 3.5in apart. Some of the ones I've found for the Hawk, even the 520 pitch, seem to have either a different bolt pattern, or a different spacing.. I have an X-Motos XMB-88 but it's the DLX version with the lights and signals... I'm going to start with the chain for now - and wait to do sprockets later, if I can.. may have to end up taking it somewhere for that.. But - for sprockets, I just need some clarification on teeth up / down for a lower top end RPM. |
11-11-2020, 09:27 PM | #2 |
Up in the front for more speed. Down in the back for more speed. Down in the front more torque less top end. Up in the rear more torque less top end. For example I'm running a 17F 40R and the engine sails at 50-55 without sounding like she wants to blow. I can also still pop up power wheelies in 1st. Win win.
11-11-2020, 09:45 PM | #3 |
Awesome - thanks!
Now I just need to find something that'll fit. The 104mm bolt spacing looks to be a little big for what I have; also 4 bolts. Unless I can just change out the rear rim? A little far for just a sprocket, but I'd like it to at least be able to hit the interstate IF need be.. |
11-12-2020, 09:20 AM | #4 |
These Chinese CG/CB engines generally can fit 17 tooth sprockets, some barely, like the Hawk, but using the 428 chain. The bikes coming with the 520 chains are relatively new (or less popular due to price, like the Pitster XTR lineup) and seem to be limited in what you can throw in the front. I would suggest simply calling the dealer (I am assuming Orion?) and see what they suggest or sell. If this is not the Orion bike, where did you purchase from?
11-12-2020, 09:38 AM | #5 |
My TBR7 came with a 530 chain, 12 front and 38 rear stock. It was way too much torque and was screaming at 55mph in this setup.
I changed it to a 13T front, 32 rear and 520 chain based on sprocket availability. With the 520 chain setup, it is bigger, so likely 13 tooth is likely the max. I did not try a 14 but thinking it probably would be too tight. See the 2021 TBR7 thread for details and ordering links. |
11-29-2020, 09:55 AM | #6 | |
11-29-2020, 08:02 PM | #7 | |
Nice! When I was out before the cold really started to settle in; I was able to hit 70 with the stock 13TF/40TR - going with the wind, and downhill lol I haven't been out just yet to get a full top speed yet - getting nippy now! I just put a 110 main jet in my carb. May go out tomorrow if it's not crappy. I bet it's still good weather to ride down in FL! *Edit* Nope - too cold lol Was blowing the snow here in VA yesterday. Couldn't get on the forums! Still need to roll my bike out and get it started. Will update!
|2020 X-Pro Titan DLX| <-- FOR SALE!! Last edited by Plump Kibbles; 12-02-2020 at 02:32 PM. |
11-12-2020, 09:56 AM | #8 |
As an observation, I think it's easier for me to wheelie with the larger front sprocket. With the smaller one that came stock the bike would run out of rpms so fast in 1st gear that the tire would drop after almost no distance.
11-12-2020, 06:22 PM | #9 | |
I'm not eh.. good with wheelies anymore. Had my BMW 650GS crush my right leg years ago and decided to take a little break from riding; my mistake riding in the rain on the side of a rocky mountain.. But, it does feel like I could pop it up - I believe I'm about 20-30lbs lighter than the Hawks. Air cooled so no radiator / fluids, looks like a smaller battery too. Easing back into the adventures again heh heh. I'm just curious why these are geared like scooters more than a dirt slingin' bike that it looks like lol |
11-12-2020, 10:23 AM | #10 |
if you can measure your sprocket bore diameter and bolt circle, you will likely find something off the shelf from JT... when i supermoto's my Roketa, i swapped in 86 ninja 250 rims, so i had to convert to 520 chain... LOL i run a 13/38 (if memory serves correctly, its been 6 years since i did it) because it was the smallest that fit my rims...LOL
11-12-2020, 06:13 PM | #11 |
Well, I need to log in more often lol I wasn't aware of the updates here.. Thanks everyone for replying!!
But, my bike is an XMOTOS model XB-88 DLX, https://www.orionpowersports.com/con...B250MANUAL.pdf <- manual for reference.. Did not get through Orion; came from Moto Pro in California - bought through Amazon. Gotta love that free shipping!! So far though, I love it - no issues as of yet. Feels just like a YZ250.. I am changing out the chain soon; already ordered. I'm at 200mi and it's starting to get a little stretched and warpy.. can also feel it now after my recent ride. Was with a few friends with their Ninjas so I was kind of limited - didn't want to WOT the entire time lol I do see the recommendation of changing sprockets with the chain - but sprockets look pretty much new, no scars or wear spots at all, and haven't really done anything demanding as far as riding yet.. I'll try to get some measurements after dinner on the sprocket in the back. Definitely won't be able to fit in a front 17T - and if I did go down in chain pitch, I'm kind of worried I won't be able to get a sprocket anywhere; and was searching and emailed JT for help but no response yet. The front right now is a 13T and, kind of worries me, I can see some rubbing on the front sprocket cover. My damn chain slide was WAY off of being close to straight when I was putting everything together and got that right.. Although, I may take it somewhere to get the back fork and alignment looked into... I have set the back tire 'true' and doesn't rub anything from the tire, but the left side adjuster will be maybe 31mm and the right will be somewhere around 34-35mm... I don't have any wobbles, I'm used to the feel of knobbies so sometimes its hard to tell, but no stability concerns. I even had my friends with me when we were out watch my back tire as I was riding to double-triple check. Seems to be all good there. But, I was looking at measurements on the diagrams from JT and wasn't matching, I have 3.5in from directly across the bolt pattern, and if I just go to the next bolt center to center it's 2.5in. The ones on JT that I found were like 4in. furthest distance from bolt to bolt. Inside diameter I'll get as well - I think I can squeeze my caliper between everything to get a measurement. Btw would rims - and I mean good ones - be any benefit over spokes? Just wondering. |
11-12-2020, 08:29 PM | #12 | |
okay so the sprocket bore diameter is 56mm (2.20in) - bolt to bolt straight across the bolt pattern is 90mm (3.5in).. I believe I may have found the one. Though, it is a 31T.. is that going to impose any issues?? As in, achieving a lower RPM for 55MPH at least - am I going to have issues off-road on inclines? I don't want to shoot myself in the foot doing that lol.. A sixth gear would just be perfect. But, already know I'd have to engine swap to do that... meh. |
11-12-2020, 07:06 PM | #13 |
http://www.jtsprockets.com/catalogue/part/JTR272/
That's about the closest thing I can find. I'm still just eyeballing everything and don't have anywhere close to take my bike to and have somewhat professional advice lol |
11-12-2020, 08:48 PM | #14 |
I believe your Bike is just a rebranded ORION RXB 250L , since you mentioned you had the lights Model . I think it would be worth an email to ORION to confirm that, if so then i can tell you for sure that the RXB 250L uses KTM style rear sprockets in 520.
You can also check Thumpertalk.com Chinese Bikes Section > RXB 250 for a lot of parts interchangeability info , as well as the RXB 250 Owners Group page on FaceBook run by David Cochrane the link to that is here :https://www.facebook.com/groups/570367237200442
11-13-2020, 12:07 AM | #15 | ||
