Raptor 200 Error code
Hey, i just received my new raptor 200 and when its Turned On , the display show me C-1850 ? It doesnt show any other info. Any idea? Faulty unit? Thanks!!
I should say the bike starts and run fine (even if it stalls when coming to a stop) , but ive called the place where i bought it, i called tao motors, i called gvabrands and no one knows anything about these bikes, they basicly tell me to call each other lol. The place where I bought it will send me a new display but i doubt its defective, the code means something..
Dealer
Hello... which dealer did you buy from???? where are you??? please tell us more info.. I think I doubt there is a code genererated... as they do not have this stuff..... I could be wrong with the new stuff for 2021./.. but ?? check your carb for sucking air or stuff like that... spray either around the mounting points... and see if it boggs... as I believe you when you say you adjust stuff... but that is usually a good place to start... so give more info please.. if you say where you are .... maybe some one local could help you... alot of members live close to you... if your lucky.. or steer you to get it fixed... did the dealer ( taotao ) .. not gva say anything about this???
#5 | |
Bike seems to be running fine now, it just take lot of time fo warm up. Takes a good 15 min for it to stop stalling. I will try to Look at the carb like you said thanks. |
pocket bike canada
They are part of GVA.... GVA has separate companies in CANADA and USA.. and ROSSO ELECTRIC STUFF..OK.. TRY THE NEW GUAGE
choke
if the bike runs ok... after it warms up... then leave it alone... these Chinese motors need to be warmed up.... the EPA setting make the carbs lean out.. for the CERTIFaCATION... .. as far as the code... I think it might have been just the guage..... as they do not have a error code setup... no computor to generate code.. try disconnection the speedo connector at the end.. I know if the speedo is not set... it starts to register the miles on the guage just sitting with the key on.. ticks away..
