05-29-2021, 11:14 AM | #1 |
Kenda K761's
Hey guys. So I bought these tires and I'm running into some confusion as to whether they require tubes? I ride a 2020 Hawk Dlx if that matters. Do you guys know if these do require tubes and if so, which ones will fit?
05-29-2021, 03:10 PM | #2 |
It's a tubeless tire, but you can use it on your rims with a tube of course.
05-29-2021, 05:05 PM | #3 |
I keep reading how a spoked rim requires a tube?
05-29-2021, 06:17 PM | #4 |
There are spoked rims that don't need tubes. The ones in these chinese motorcycle do need a tube, even if you put a tubeless tire, you will need to put a tube.
05-29-2021, 06:08 PM | #5 |
The tires themselves won’t convert spoked rims to a tubeless set up ,you can buy a conversion if you like ,but until you seal off the spoke holes you need to run tubes .
