Old 06-22-2021, 05:30 PM   #1
BakedOregonian   BakedOregonian is offline
Just lost all power to my Hawk DLX??
I added a pod filter and removed my airbox and now I have no power when I turn the key. No electronics were tampered with and my battery is fully charged. Any ideas? Thanks guys.
Old 06-22-2021, 05:32 PM   #2
Blown fuse? disconnected ground? Check that you didn't accidently unplug a connector.
Old 06-22-2021, 05:39 PM   #3
Both positive and negative are attached to the battery, is there another ground? My dashboard lights up when I kickstart her but she doesn't start.
Old 06-22-2021, 05:48 PM   #4
Check bolts where the ground is attached to the engine and connection where the positive attaches to the relay.
Old 06-22-2021, 05:49 PM   #5
Make sure you didn't accidently turn on the kill switch.
Old 06-22-2021, 05:59 PM   #6
My voltmeter is getting activity at the positive relay and negative.
Old 06-22-2021, 05:38 PM   #7
J4Fun   J4Fun is offline
You said removed my air box, so I too would agree with Jerry!
Old 06-22-2021, 05:48 PM   #8
Another thought is the injector plugged in? I'm not around my bike so thinking out loud?
Old 06-23-2021, 12:02 AM   #9
Plump Kibbles   Plump Kibbles is offline
Continuity check off the negative lead from battery side to the engine? There should be a ground lead off the negative terminal with a ring connector that the terminal screw goes through.. maybe? Also +1 JerryHawk for fuses - I can't think of anything other than maybe the ground wire itself loose from the terminal side. Could have come loose from the crimp as well? Did you disconnect any of the wiring? I wouldn't say idle, but you did put a pod filter on - which when I did, I had to raise my idle; but I don't think that's the issue... Last thought - maybe look at the voltage regulator plug? Just tossin out ideas..
|2020 X-Pro Titan DLX| <-- FOR SALE!!
Old 06-23-2021, 10:45 AM   #10
Thank you my friends! Even though the fuse looked fine it was indeed faulty. Lesson learned.
Old 06-23-2021, 11:58 AM   #11
Let us know how the dlx runs with the pod set up.
2021 Tao Tbr7 - "Lucille"
2009 Q-link Legacy 250
Old 06-23-2021, 02:46 PM   #12
It added 5 mph easy for starters! I don't do any serious off roading so I shouldn't have any issues. It took a few for my efi to adjust but I am glad I made the mod.
