Old 06-26-2021, 12:44 AM   #1
HotRod   HotRod is offline
HotRod's Avatar
Starter, battery or starter switch?
Just got a new starter from Orion. Bike started right up with electric start. An hour later starter switch does nothing. Can bypass with relay and screwdriver. But seems to drain the battery. Getting regular voltage before bypassing switch.
Old 06-26-2021, 11:28 AM   #2
I would probably eliminate starter as being the culprit. I figure your old starter is probably still good as well. I can't see the switch draining the battery.
Old 06-26-2021, 07:26 PM   #3
XLsior   XLsior is online now
XLsior's Avatar
Could be a dodgy solenoid relay.
Old 06-26-2021, 08:41 PM   #4
krat   krat is offline
More than likely it is not the solenoid.
Check and insure both the ignition and the kill switch are in the run position. That eludes more people than one would expect.
Disconnect the lead from the solenoid to the starter and press the starter button, you should hear the relay click if its good. Usually you can't hear it due to the sound of the starter motor.
If no click check the connectors on that circuit. If you have a meter check for continuity through the circuit.
The circuit is dead simple, a wire running from the solenoid to the starter button and back. It is not tied to or over run by any other system except the kill switch.
