10-25-2021, 12:30 PM | #1 |
Oh, Come On! I Changed The Main Jet On My 250 And Now It WILL NOT START!!!
WTF? I went from an 88 main jet to a 110 on my 2021 Tao Motor TBR7 "250". I know I have it together correctly (after a few tries). It cranks and cranks, but no start. Once it almost started, before battery ran too low to crank further.
Note: The head of the the new main jet screw is quite a bit larger than factory, but I don't see how that could be an issue as it is on float bowl side of carb. Any ideas? |
10-25-2021, 12:47 PM | #2 |
Sounds like a Mikuni jet put in a PZ???? Just guessing without pics
10-25-2021, 01:01 PM | #3 |
I assume WTF means What's The Fix? Maybe the float bowl wasn't quite filled yet when you were cranking? Just a thought
10-27-2021, 01:34 PM | #4 |
I'm sticking too this thought...
10-25-2021, 05:56 PM | #5 |
Does it matter??? 110 is 110 in either case.
10-25-2021, 06:07 PM | #6 |
Yes it does matter. Mikuni and Keihin jets are not sized the same.
https://www.blasterforum.com/attachm...son-jpg.13852/ By the way, your responses and comments on this forum often come off as very combative - especially to people trying to help you. I'm guessing it's a translation/ culture thing. |
10-25-2021, 01:01 PM | #7 |
Are you getting a gasoline smell when cranking? If so, this may be a shot in the dark, but I’m thinking it’s possible the needle may be set too high. If so, it could be spraying fuel from the main jet before the throttle is opening.
If you aren’t smelling fuel, since you had the carb apart, don’t rule out the simple things or the possibility of something unexpected like the float valve needing readjustment if the float tab accidentally got tweaked.
2021 Lifan Xpect EFI 2012 DF250rtc 1982 Yamaha Virago XV750 1982 Honda Twinstar CM200 |
10-25-2021, 01:22 PM | #8 |
Kill switch in the Off position?
2021 Lifan Xpect--sold 2022 Lifan KPX 1972 Honda CT90--The Carrot 1969 Honda CT90--The Tomahto Cheesy is the WDK (workplace drama king). Now retired. Nope, back in the saddle. Nope, finally retired. Climate: The Movie https://www.youtube.com/watch?v=A24fWmNA6lM How our government really works https://www.youtube.com/watch?v=QjadCd0VRBw Question all authority.....think for yourself |
10-25-2021, 01:26 PM | #9 |
Man, you aren’t kidding. I have gone through troubleshooting all kinds of things and it would end up being something that simple. (petcock is off because I turned it off to remove the carburetor). Lol
10-25-2021, 04:29 PM | #10 |
In EITHER position it cranks!!! Seems like in only one it should.
10-25-2021, 05:26 PM | #11 | |
How about the petcock? Is it on? Enough gas?
10-25-2021, 05:55 PM | #12 |
10-25-2021, 05:53 PM | #13 |
I'm curious as to reason for going from a #88 to a #110 main jet in one shot...
There has to be other sizes in between 88 and 110 to try, usually one size bigger, at a time, and then see if the performance improves. |
10-25-2021, 06:20 PM | #14 |
It should start even with a too-large main jet, since the pilot jet would be the one involved at low RPMs. I wonder if the fuel or air mixture screw is turned all the way in. I'd suggest you go over everything again from square one, to make sure you didn't miss anything.
2021 Lifan Xpect--sold 2022 Lifan KPX 1972 Honda CT90--The Carrot 1969 Honda CT90--The Tomahto Cheesy is the WDK (workplace drama king). Now retired. Nope, back in the saddle. Nope, finally retired. Climate: The Movie https://www.youtube.com/watch?v=A24fWmNA6lM How our government really works https://www.youtube.com/watch?v=QjadCd0VRBw Question all authority.....think for yourself Last edited by TominMO; 10-26-2021 at 11:38 AM. |
10-25-2021, 09:13 PM | #15 | |
And no, I did not touch the air/fuel mixture screw one iota. |
