07-04-2022, 05:09 PM | #1 |
Needed: CG250 4 Stroke Motor mounts
Hi all,
I need help. I bought a CG250 clone from Alibaba. I am mounting it on a CB250 Nighthawk Frame. The stock mounts are close but not quite right. Does anyone know where I can scare you the front and rear motor mounts? The only ones that work are the too 2 mount plates. I sure would appreciate some direction, even if it is modification advice. |
07-05-2022, 08:10 AM | #2 |
Post up, or link us to some pictures so we can see what you're dealing with. I've never heard of somebody doing the swap, though I've heard it's possible.
07-05-2022, 08:22 AM | #3 |
You will more than likely be better off fabricating mounts form steel plate. Even if you found mounts they probably won't be exactly what you need.
07-05-2022, 01:00 PM | #4 |
Also, the rear mounts are in the frame. Post up a picture of the motor, so we know what you're dealing with, the left and right sides.
cg250, motor mounts |
