02-12-2023, 09:07 PM | #1 |
Templar 250 skid plate
I found a skid plate that fits the base Templar pretty well all things considered. Unfortunately they sent me blue when I ordered black so I need to exchange it but since I had it I tested the fitment and it ain't bad. The included mounting bracket works and it looks pretty good on the bike. There is a hole in the back that lines up with a frame crosstube and can be attached with a zip tie. The base Templar frame gets much wider at the foot pegs so it will fit better if I heat up the plate and flatten it a little or cut away a bit in that area.
I was considering making one from a HDPE cutting board but this is a lot less work. I wish I had a heat gun but maybe I can use a propane torch instead. Let me know what you think about the fitment. The skid plate is Cycra SKU: 1CYC-6206-12 and fits 2010-2013 Yamaha YZ450F.
22 Templar 250 Last edited by Fast_Freddy; 02-13-2023 at 01:37 AM. Reason: added photos |
02-13-2023, 07:15 AM | #2 |
I made one for mine out of 1/8" Aluminum, added some to the sides in front of the shifter/brake pedal, to add a little more protection.....don't have any pics, but will try to get some
02-15-2023, 12:23 AM | #3 |
Nice. I'd like to see what it looks like when you get a chance. Learning to TIG is on my list of things to learn someday.
22 Templar 250 |
02-15-2023, 10:02 AM | #4 |
Only pic I have on my pc, doesn't really show it.....will try to get a better pic
02-15-2023, 11:22 PM | #5 |
Thanks! I zoomed way in and got a pretty good look. I'd be happy with that.
22 Templar 250 |
02-15-2023, 12:26 AM | #7 |
If I had left the oem graphics on the blue might have worked but definitely not with the monochromatic black/orange theme. I ordered a black one today.
22 Templar 250 |
02-13-2023, 10:13 AM | #8 |
I used the Cycra plate for an 05-19 YZ250.. it fits well except it needs some foam or delrin spacers in front to be able to tighten up.
https://www.amazon.com/gp/product/B0725FJRFR/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 |
02-15-2023, 12:27 AM | #9 | |
22 Templar 250 |
02-18-2023, 08:57 PM | #10 |
My new black skid plate is done. I had little success bending it with heat so I ended up cutting it instead. It fits pretty well with the included mounting bracket and a zip tie at the rear. It's not the best skid plate ever but it's a helluva lot better than no skid plate. I added a hole so I can change the oil without removing the skid plate. Cost: $65
22 Templar 250 Last edited by Fast_Freddy; 02-18-2023 at 09:37 PM. |
02-18-2023, 09:57 PM | #11 |
Have you ridden with the new plastic skid plate? The stock plate on a templar X sounds like a bad hail storm on some loose gravel. Be nice to quiet that down a bit.
Also think it would fit over the stock plate? Nothing like double protection.
1985 HD FLT 1995 HD FXD 2000 Honda RC51 2022 Xpro Storm 125 - (grandson) 2023 Xpro Templar X |
02-19-2023, 12:37 PM | #12 | |
Edit: Rode a little today and can't tell the skid plate is even there. None of that metal skid plate resonance and reflected sound waves.
22 Templar 250 Last edited by Fast_Freddy; 02-19-2023 at 09:14 PM. |
