08-24-2023, 07:08 AM | #1 |
Linhai 260cc 4X4
I got a Linhai 260cc 4x4. when i try to start it nothing happens! After looking at the wiring, I found that there are some loose wires. can someone tell me what diss is (1 and 2) and where these lines (3) should be connected
08-24-2023, 09:46 PM | #2 |
One of them might be the CDI unit. The other one maybe a turn signal clicker? Trace the lines. Anything from the sender on the stator, which should come out of the case on the left side between the stator and sprocket cover (under the sprocket cover). That unit will be the CDI. Output might go directly to the coil.
08-25-2023, 05:33 AM | #3 |
The CDI is located in the front.
08-25-2023, 07:56 AM | #4 |
#3 is probably a ground.
08-26-2023, 10:56 AM | #5 |
On my new 300cc 4x4, number 2 is the back-up alarm.
08-26-2023, 10:57 AM | #6 |
Number 1 is the ,I think,reverse limiter,sorta like a rev limiter.
08-26-2023, 11:00 AM | #7 |
32003 BATTERY CABLE POSITIVE 1 LH260ATV.19.2a-1, 9. 32038 REVERSE GEAR WARNING(FOR 4WD) 1 4AL-82600-00, 10. 22002a REVERSE SPEED LIMITER ( FOR
08-26-2023, 11:02 AM | #8 |
I've unhooked number 2 on mine,like I said before,I don't need this end of the county to know I'm backing up,lol
the thing is pretty loud,be deer hunting and trying to be quiet and turn the key on and the atv be in reverse,BEEP,BEEP,BEEP |
08-26-2023, 11:05 AM | #9 |
Does it have a winch?Maybe the bare black wire is a winch wire,on mine I had an extra black & red wire I had to attach to the battery along with the negative & positive battery cables.
