Old 09-03-2008, 09:24 AM   #1
ww1putt   ww1putt is offline
SLA 265 cooling issue
I have a sunl SLA 265 (water cooled) the issue is the water is not circulating and the engine is overheating. Is it possible that the thermocoupler is bad? Where is the best place for replacement parts? Thanks for your help.
Old 09-03-2008, 04:49 PM   #2
katoranger's Avatar
Is the thermostat stuck? Check that first and then take a look at the water pump.
Allen
Old 09-04-2008, 12:06 AM   #3
warrior91   warrior91 is offline
Probably the impeller itself...seems a common issue on other sites more familiar with the water cooled set...scoot dawgs... For some reason most of us here have lo-tech air cooled....but they run!
When you diagnose or get it fixed be sure to enter your findings back here...
:idea: plastic impeller,missing teeth and spinning freely on shaft is my bet
'91 Yamaha Warrior- stage 2
'83 Honda ATC 70
'08 Yongjiang 125cc mx (Loncin)
'08 Yongjiang 150cc atv (Jinlong)
Old 09-04-2008, 06:35 PM   #4
Guest
Posts: n/a
My name says it all!!!!
