Zong Sierra 200 Gear Oil Change
Greetings:
I recently bought a Sierra 200 and it works great. I really like it a lot. This is my first MC and I use it to go to work mostly. The "manual" says to change engine oil every 800 miles and I figured that out pretty easy. It also says to change gear oil every 1000 miles. I do not see how to drain and refill the gear oil and the manual is almost useless. Anyone out there able to give me a quick set of directions for gear oil change? Thanks, Ken |
Interesting, unless your bike has a completely different motor that the rest of us, the tranny is lubed by the engine oil and no separate change is needed. Can you post a photo of your bike/motor?
2009 XR650L Big Red Pig Tusk bar risers 2007 X-Moto(Jetmoto) GY250 --mods--- 15/40 sprockets UNI Pod Filter 2007 Shineray TMS 200XYi--Betsy ![]() Betsy Mods:______________________ Acerbis DHH headlight FMF Powercore pipe Uni Pod Filter |
#3 | |
Welcome, and congratulations on getting your first motorcycle! ![]() Liverchip is correct. The Zongshen Sierra 200 uses the same oil to lubricate both the engine and the gearbox. I change the oil in my Zongshen every 1,500 miles or so. Continue to change your oil frequently, and you should continue to get good service from your engine. ![]() It is very important to clean the reusable oil filter, and to perform several other checks at every oil change for the Sierra 200GY-2. Therefore, I will soon post this information in another thread. Spud ![]()
Thanks Guys for the quick reply.
When I first got the motorcycle it looked (at least externally) that the lub oil was all that needed to be changed. Then I came across the comment in the paper work that mentions "gear oil" They must have been talking about the same oil as lub oil. Since I had never actually dismantled a motorcycle engine it occured to me that maybe I did not really understand how it was put together. I figured that it was safer to ask here about gear oil and make sure I don't miss something. Again, thanks, Ken |
Be careful of what you read in the paperwork!!!!
