G.R,Michigan
Hello my name is Radgy,i'm building a mini-trike,i got this motor for it:
http://cgi.ebay.com/ebaymotors/ws/eB...3AIT&viewitem= i guess its a replacement for gio mini atv's.Got it new on ebay.Anybody have diagrams for it?It cam with the carb(not on)some seal,but no directions on how it goes on,where the seals go.Didnt even come with a list of what came with it.When i asked the seller...he pointed me here.I have a bunch of modual's that came with it,but it dont tell me what they are,or where they go.I dont see any linkage for a throttle cable to go(only the manual choke,is the throttle electric? thanx |
Welcome! I am afraid that I can't help you with that engine, but we have a lot of knowledgeable Gio owners registered here. I am confident someone will soon come along and help you get the information you need.
![]() Spud ![]()
Welcome. Appears to be an electric-start only Lifan engine. The throttle cable has no linkage as such. The cable just goes inside the carb top cap and hooks onto the slide. Don't know what carb came with it, but the choke is usually a lever incorporated into the carb itself. No cable.
The manifold should come with a couple of gaskets and a plastic spacer to keep engine heat from being conducted to the carb body. The manifold is bolted to the engine with one of the gaskets and the carb goes at the other end with the plastic spacer. The joint spacer-manifold has another gasket and the joint spacer-carb doesn't need one as the carb has an "O" ring seal built into its flange. The little black box that comes with it is the CDI ignition module. It'll be the same as you already have on the bike so just keep it as a spare.
Jincheng Monkey JC50Q-7 (two of them) Skyteam Dax replica ST110-6 (two of them) Zongshen ZS125-43 Qingqi QM200GY-BA Super Motard Yamaha Virago XV1100 Triumph Bonneville SE Qingqi QM110GY PGO Bug rider 250 Buggy |
Yes it has that kind of choke.and it is electric start only..what do you mean under under the carb top cap,you mean the under the air filter,or do you mean the thing thats on the side,that you un-scew?But thanks for answering.
oh,another thing i got a throttle control handle for it,does they work on either a 2 stroke,or a 4 stroke?cause i bought some on ebay...the left side has the buttens for light/horn/blinkers..and the add say's specifically that it will work on either,so i bought the right side,with the throttle/start on it,from the same store...thinking they were a match,but after a question on my engine from the seller,i looked and the add dont say weather or not it will work on a 4 stroke....does it matter?Dont mean to ask stupid questions. |
#5 | |
Switch gear operation has nothing to do whether it's a 2 or 4-stroke.
o.k thanx
