150cc GY6 Motor Scooters.... Re-Jet for Power.....
OK.... Here is a very easy fix for a bone stock 150cc GY6 Scooter. Just simply re-jet the thing. Main and Idle Jet...
Replace the Idle Jet with a 40 Replace the Main jet with a 108-112 roughly Most of the 30 lb. boat anchor mufflers with the cheap aluminum wrap, and rivets on the ends could be cut off.... and use a short performance muffler welded on in its place.... You don't have to go loud to get performance.... Use a short muffler off a 250cc or larger engine.... with a larger outlet on the back than stock. Don't need to make any other changes.....
<a href="www.atvwholesaleoutlet.com" target="_blank">ATV Wholesale Outlet . 14com</a><br />4551 Auburn Blvd<br />Sacramento, CA. 95841<br />(916) 922-3333 |
Discussed here:
http://www.chinariders.net/modules.p...ewtopic&t=8995 |
I drilled out the pilot, rather than buy a new one (can't remember what size), and it starts beautifully with a Uni and free-flowing exhaust. I used a 120 main, and it's not enough. I gotta go buy more jets.
Thanks for your comments Doug.
