Cheap Zong project bike?
http://yakima.craigslist.org/mcy/2091538960.html
If I can get it for $200 may be a good engine donor at any rate... UPDATE: I offered the guy $200. I'm dying for a project.
Happy to serve. |
Help me out here, because I don't "get it"?
I was recently at a place, for the want of a better term, that was a private junkyard. There were all manner of gasoline powered things there, all with "bad coils", or at least that is what I was told. I played Yamaha/HD mechanic in the late 60's, played car mechanic in the 70's, played with trucks and buses in the 80's. I have probably worked on 500,000 vehicles (if not more, and not counting stationary equipment, boats, ships, and airplanes). I recall only ever replacing 3 coils, and that was due to a bad oscilloscope pattern, the vehicles ran, not specifically "well", but ran good enough to get them to a garage. Is a vehicle having a "bad coil" become a kind of generic ailment? |
#3 | |
Happy to serve. |
I'm thinking bad diagnosis as well.
I've tested several coils according to the procedure in Hayne's manuals, and I've never found one so bad that the car wouldn't run, despite being out of spec. The only coils of any description that I've ever seen fail are solenoid coils for water control valves. That is largely because the design called for them to be open 24/7, and they would only ever close in response to a cut signal from the PLC. Ridiculous design. Doc, did the seller respond?
Yeah. He'll let it go for $200. 2,500 miles, no damage. Clear title. Sitting in garage for the past year. Not wrecked or rusted. Light wear marks on seat and tank, no rust. No other known mechanical or electrical issues.
I think I'll take the trailer and look at it. I'll bring a battery. If it's just the CDI I can fix in 10 minutes for $10 and sell it in the Spring for $500-$750 easy... Or save the motor for something else! What do you guys think? Should I gamble?
Happy to serve. |
Why not?
Not too sure on Chinese re-sale though. I am sure if you are careful, and not wind too many $ in it, you can't go too far wrong @ $200. |
Agreed on both counts. Sounds like either $200 worth of donor parts for another bike, or a resale value of X. Even if you only get $400 for it, you doubled your money (minus the CDI and your time of course).
Grab it!
At worst: pieces
At best: a donor engine, and a street titled home for a CR450 |
#9 | |
Happy to serve. |
Doc, most likely a failed CDI. Seller thinks it a coil since it does not have spark. Probably can ID a coil, but has no idea what a CDI is.
Allen
Plus I have Bill's drowned CDI which might work. Heck his solenoid was still good. Plus Spud's a Zong parts dealer. What more could I ask for?
Happy to serve. |
#12 | |
Really. That would be grea :P t. A punched out Yamaha/Zong OHC motor? That would be great. I had a streetbike with the 230 OHV Hondoid engine and I was not impressed with it at all.
Happy to serve. |
#14 | ||
As I encouraged you via PM, I say go for it, Doc! ![]() ![]() ![]() Spud ![]()
#15 |
The seller called to confirm it's still available. I'll check it out tomorrow morning.
Happy to serve. |
