1st start after winter help = QLink Legacy 250
Howdy all!
Having a bit of trouble getting her started. Last winter it fired right up in spring. This winter no. I sprayed some carb cleaner in the spark plug hole and it fired briefly and then dies. Almost smacks of a fuel delivery issue. This is the same as a CF Moto V5. Please and thank you for help troubleshooting. Phil
2008 QLink Legacy 250 1982 Honda C70 Passport 2008 Hensim Hunter ATV 150cc |
It's time to remove the carb, dismantle it and clean it, Phil. There isn't likely to be a shortcut.
I agree it is a fuel issue. Did you put Stabil min the fuel system before storage?
Happy to serve. |
#4 | |
Phil
Stabil is a wise move every winter. I use it in everything from my chainsaw to my boat. Even though the bikes run all year, I use it in the wintertime just in case they sit too long.
Happy to serve. |
I would also suggest a spark plug change. I use NKG # DPR7AE-9 gapped at 0.32. Although my wifes V5 fired right up, it didn't really run all that well until I did. I always fill both of our bikes up with gas in the winter, put in some staybil and ride for a few miles in order to get it throughout the carb. Then in the spring, I'll squeese in as much fresh 93 octane as I can. Just a suggestion.
