Old 06-23-2017, 08:56 AM   #91
Originally Posted by XDoubleXA View Post
I see no place to plug and play this........lol
http://www.ebay.com/itm/H4-5-COB-HID...72.m2749.l2649
Sure, you unplug old bulb and plug in new harness. Just have to figure out which adapter ring to use for the light to install the new light. Instructions were useless.
2020 Kawasaki Vulcan S
Old 06-23-2017, 10:10 AM   #92
Useless is an understatement. It's easy enough to figure out though, take the bulb you remove from the headlight, match the adapter ring to it, orient said adapter ring so the concave side matches that same bulb you took out, install adapter ring by lining up a small peg hole on the ring with a little alignment peg on the bulb, push it past that, and twist to lock the ring in place. Just make sure you orient the bulb correctly with the alignment tabs on the adapter ring for the housing so the 3 low beams that fire face up and you are good.
As far as not seeing the plug and play part... You don't see the 3 prong connector on the right side of the picture? That's a classic H4 plug.
Old 06-23-2017, 12:06 PM   #93
XDoubleXA   XDoubleXA is offline
XDoubleXA's Avatar
As far as not seeing the plug and play part... You don't see the 3 prong connector on the right side of the picture? That's a classic H4 plug.[/QUOTE]
yeah, i really cant find it. my other headlight plug in the harness is different
Old 06-23-2017, 12:08 PM   #94
XDoubleXA's Avatar
yeah, i really cant find it. my other headlight plug in the harness is different where do you plug it in the harness at?[/QUOTE]
Old 06-23-2017, 02:00 PM   #95
yeah, i really cant find it. my other headlight plug in the harness is different[/QUOTE] So your existing headlight bulb doesn't have 3 prongs like the one in the lower right hand corner of the picture?
Old 06-23-2017, 02:05 PM   #96
[/QUOTE] your existing bulb should be similar to this one.
Old 06-23-2017, 04:51 PM   #97
Sir kayakalot   Sir kayakalot is offline
Sir kayakalot's Avatar
I'm fighting this light issue right now myself. I feel like an idiot. I can't figure out for the life of me how to get the damn bulb back in. I found the black ring that matches the shape of the old bulb. I can snap it on and twist it and lock it on the new bulb. Am I supposed to have the spring and white plastic piece on too? I've tried it every way I can think of. Help me before I burn the whole SOB to the ground lol!
Hawk 250 Mikuni carb 115 main. De-catted pipe. Air box mod. 15/42 sprockets. Digital instrument cluster, FMF end cap on muffler, handlebar toolbag, Custom foot pegs
Old 06-23-2017, 05:14 PM   #98
Ok never mind. A miracle happened and I figured it out
Old 06-23-2017, 10:08 PM   #99
Now that it's dark outside I went out and did a test run with the new headlight, very impressive. Huge difference compared to the stock bulb which is an absolute joke. Thanks for the link pcspecialist
Old 06-26-2017, 10:49 AM   #100
XDoubleXA's Avatar
I got it, I'm retarded.
Old 06-26-2017, 11:37 AM   #101
LOL, we all have those moments. Never, ever try working on something after a long days work. I'll get brain lock up and give up then get up the next morning and have the "you dumb ass, why I didn't see that yesterday" moments.
Old 06-26-2017, 01:46 PM   #102
XDoubleXA's Avatar
Exactly what happened.
Old 07-29-2017, 07:11 PM   #103
pcspecialist   pcspecialist is offline
Old 07-29-2017, 07:17 PM   #104
I thought I had posted about the 2009 R1 MOSFET R/R swap in this thread but apparently, I posted about it elsewhere.
I got it installed and it holds the voltage between 14.1v and 14.3v, much better than the OEM's under 13v to a little over 15v.
From the OEM R/R. the black wire is a sensing wire, it isn't used with the MOSFET R/R. Red is +, Green is - and the other two are the stator. I plugged the middle gray connector and hooked up the two stator wires to the remaining gray connector terminals but you can do it in any order you like.
Old 07-30-2017, 09:53 AM   #105
ben2go   ben2go is offline
I do this mod to all the bikes I have if they don't come with a mosfet rectifier. I use the FH012AA or FH020.
Search this Thread:
Advanced Search
Display Modes
