Old 09-14-2012, 05:33 PM   #1
Cron   Cron is offline
electronics are dead
hello, hopefully you can help me with this...
bike was sitting for a couple weeks. now I have no lights, horn, starter, etc.
ignition key seems to work and I can kick start it and drive it around.
tried charging the battery for a couple hours.
I could only find one fuse which is fine.
any idea how to troubleshoot this?
Thanks!
Yingang YG200-8
Old 09-14-2012, 05:43 PM   #2
What's the battery voltage with the bike off?
CB's are known to have terrible batteries stock. May simply be dead.
Old 09-14-2012, 05:49 PM   #3
not sure I'll try to find one.
what about if I have the battery charger hooked up and still nothing, shouldn't I still get some juice out of that?
Yingang YG200-8
Old 09-14-2012, 06:01 PM   #4
Maybe not. If the battery is internally shorted due to sulfation it won't take a charge.
Also check your connections, the ground cable in particular.
Old 09-14-2012, 08:10 PM   #5
this sucks, i have someone checking out the bike tomorrow and the electronics are dead. doesn't seem to be a loose connection. hopefully it's just the battery but the fact that I can't even get a weak horn or lights when the charger is connected to the +/- terminal concerns me. ground wire seems solid.
Yingang YG200-8
Old 09-14-2012, 08:25 PM   #6
battery is fine i checked it... def got juice there
Yingang YG200-8
Old 09-14-2012, 09:12 PM   #7
You said it runs if kick started? Do the lights work with it running?
Old 09-15-2012, 12:55 AM   #8
What's the voltmeter reading on it?
Old 09-15-2012, 05:50 PM   #9
Guys, thanks a lot for the ideas.
I finally figured it out... I took my dog out in the middle of the night, said a little prayer and turned on the igntion, jiggled the ground terminal connection and everything powered up. I def could sleep better last night with that resolved.
Turns out that the ground battery connection was losing contact due to corrosion or whatever and the ignition switch is going a little wonky. The ignition switch is a concern, but at least I know what the issue is and it's generally functional. Fairly basic stuff, I just didn't put all the pieces together right away, and God helped me out a little there.
This forum is the best!
Yingang YG200-8
Old 09-15-2012, 05:53 PM   #10
So, you're saying that prayer did the trick?
Old 09-15-2012, 05:56 PM   #11
I'm not too proud to ask for a little help! :P
Yingang YG200-8
