Old 07-12-2007, 11:56 PM   #16
knothead   knothead is offline
Originally Posted by pumpkin
i've had good luck with penzoil in my autos but i guess thier mc oil isn't as good thanks for the heads up
I meant the regular stuff for cars. After running Pennzoil for a while drop your oilpan. You'll make the switch to Castrol GTX right away. Pennzoil leaves a tarry coating on the inside of an engine. I wouldn't think about putting it in a bike. If I HAD to run Pennzoil in a car I'd keep a quart of ATF in the engine with it just to keep things clean.
Old 07-13-2007, 12:11 AM   #17
pumpkin   pumpkin is offline
i've got a 1991 s-10 4.3l v6 4x4 120,000 plus or minus miles on it bought it with 70,000 miles been useing penzoil ever since never had the engine apart. i guess it all goes back to personal preferance. maybe if/when i have to tear into it i'll see you're right and change brands ,but for now i have no reason to change.
06 american lifan 200 gy-5
Old 07-13-2007, 12:32 AM   #18
AZ200cc   AZ200cc is offline
I have taken apart Penzoil a engine....Sludge and slime about a 1/4 inch thick. Been a Valvoline guy ever since. Penzoil changed the formula for a reason...Not sure how the new one is.
<br />2001 Suzuki DR200SE<br />1997 Suzuki RM250 YIKES<br />1995 Yamaha Breeze 125 daughters<br />1991 Honda XR80r Restored<br />maybe a 2003 Yamaha TTR90
Old 07-13-2007, 08:29 AM   #19
Savage   Savage is offline
There's 2 more guys that have torn into engines running Pennzoil saying the same thing I've heard from others over the years.
Maybe that's why the shops use pennzoil and charge little for an oil change.
One time in the cold winter I had a shop change my oil but asked them to use Castrol GTX and the price was almost double.
Old 07-13-2007, 10:37 AM   #20
goldshadow   goldshadow is offline
I with you AZ200c I have had a Chevy 350 that was just a mess when I tore it down. I ended up just buying a reman and putting it in instead. I would not want to try Penzoil again after that.
1975 Honda Goldwing GL1000 <br />2007 American Lifan GY-5 Licensed in NE
