01-24-2015, 12:54 PM | #31 |
I'm in Rockland county
01-24-2015, 01:22 PM | #32 |
It could be tough to find slow jets for that carb. A 30mm Mikuni is much easier. Here's one: http://www.ebay.com/itm/Carburetor-A...c1c85d&vxp=mtr
01-28-2015, 10:06 PM | #33 |
hey weld
where can i find the replacement jets for the 30mm mikuni carb. i ordered the carb but want to up the jets like you recommended. 110 main and should i do 30 0r 25 |
01-29-2015, 06:44 PM | #34 |
The slow jet choice depends on your specific bike and your elevation. With a stock pipe near sea level, I'd stick with a 25. With a free-flowing muffler, try a 30. Whatever your bike needs to start quickly and idle smoothly.
Another way to look at it is if the pilot mixture screw needs to be backed out more that two full turns, your slow jet is too small. Remove the slow jet and main jet from your carb and then hit www.jetsrus.com. Compare the jets from your Mikuni to the jets in the pictures, and ensure that the measurements match. Once you've found a match, you'll learn what the numerical designation is for your jets, and which point you can shop at www.jetsrus.com or eBay.
01-31-2015, 08:15 PM | #35 |
Mine came with a 20 and a 100. Needle has not been touched starts with a quick bump of the starter or 1 -2 kicks, I'm leaving mine like it is for now.
If you're gonna go, go with a smile. (The Joker) |
01-31-2015, 08:48 PM | #36 |
hey Gr8rcher
hows the bike run now ever since the valves were adjusted and the new carb? |
01-31-2015, 09:41 PM | #37 |
Couldn't be happier
02-01-2015, 12:32 PM | #38 |
Awesome! I'm glad that worked out for you. You'll now have the ability to change jets if you make changes to the intake and exhaust.
02-01-2015, 05:38 PM | #39 |
Have you ordered/installed the front sprockets?
02-02-2015, 05:29 PM | #40 |
i did install a new front sprocket. i went with a 12 tooth
the original one was a 14 tooth. Big difference it bottom end |
02-02-2015, 06:56 PM | #41 |
I'll bet it climbs any hill you point it at.
02-02-2015, 10:05 PM | #42 |
i hope lol. Stillwaiting for the spring this ny weather is killing me.
I should be getting my new 30mm muniki carb in like you suggested any day now. Cant wait to install that. |
02-05-2015, 09:09 AM | #43 |
FedEx Smartpost Sucks it took 6 days to get my carb, from Cali to TX usually takes 2-3 for a USPS package to arrive.
02-05-2015, 10:44 PM | #44 |
yes took for ever. Got it today finally lol
Prob sat or sunday ill install it. Sucks because its going to snow sunday and monday now i can't even test it lol my luck. |
02-09-2015, 04:03 PM | #45 |
hello, nice bike! how is the carb working out for you?
